Old 10-03-2024, 03:59 PM   #1
ModelA29
ModelA29's Avatar
Default Re: Title for car where engines are swapped
Originally Posted by John Gibson View Post
I don’t know about Model A & T engines but no flathead V8 engine in the 1930’s had a serial number stamped on it.
The serial number on the T & A engines WAS the serial number of the car. The B engine still had the serial number pad but the actual serial number was stamped onto the cast in pad on the top of the flywheel housing. The V8 flathead also had the serial number on the flywheel housing.
ModelA29 is offline   Reply With Quote
Old 10-03-2024, 05:26 PM   #2
Charlie Stephens
Minor correction. The V8 serial number was on a pad on the transmission case and not the flywheel housing (in addition to other locations).
Charlie Stephens
