Old 07-30-2024, 05:59 PM   #1
Thodge
Thodge's Avatar
Default Re: Touchy Accelerator
The car does have a rug so that does pose a bit of a problem with using a big block of wood on the floor. I think the problem that we’re having with the footrest is that we’re both tall, have big feet, and it’s a coupe. You are limited as to how much you can roll your foot when your knee is jammed in between the steering column and the shifter. It’s easiest to just use your toe on the pedal button but that obviously makes it more difficult to be smooth.
Thodge is offline   Reply With Quote
