Old 07-22-2024, 01:54 PM   #1
vaford
Default Re: What are some of the counter intuitive things you have learned about a Model A?
How do you remove the fuel tank from a 1929 murray body town car. Thanks for any help,vaford
vaford is offline   Reply With Quote
Old 07-22-2024, 02:17 PM   #2
alexiskai
alexiskai's Avatar
It’s not exactly the same but there’s a video series on how to do it for a ‘31 fordor. Might help. https://youtu.be/kjYXME4dxgM
Old 07-22-2024, 02:58 PM   #3
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Well, to begin with, welcome to Fordbarn!
Next, -are you working on a Town Car, or a Town Sedan?
And 3rd, the video is going to be misleading because it is totally different bodystyle.
The basic nutshell of what you will need to do is remove the Firewall Filler panel located under the Gas Tank portion of the Firewall and the lower cowl section. Then remove all of the fasteners that are attaching the tank to the upper section of the body. At that point, the Gas Tank drops down from the body and comes out from the bottom. If you still have questions, consider starting a totally new thread and I can walk you thru it in even more detail.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
