Old 07-17-2024, 08:28 AM   #1
Bob Bidonde
Bob Bidonde's Avatar
Default Re: Mystery Water Leak
mgambuzza, I urge you to replace the fan on your car with a reproduction cast aluminum one. The fan you are running is prone to fatigue cracking and throwing a blade. Failure typically occurs at the bolt holes attaching the fan to the hub.
Bob Bidonde
Old 07-17-2024, 08:56 AM   #2
mgambuzza
mgambuzza's Avatar
Excellent advice - I will also order this with the water pump and check off a couple additional items for the old girl. Thank you!
Update - wow, going through all my regular suppliers and it seems there is zero supply of two blade fans. I'll keep an eye out for them.
mgambuzza is offline   Reply With Quote
