Does anyone know a current good part number for 3-5/16" Piston Rings (0.125" oversized) for the ~42-48 pistons. I have a set of aftermarket three ring pistons that uses the older ring package that was the same on the factory Ford pistons in 42-48.
I need a set of rings where it has 3/32" top rings and 5/32" oil rings preferably with the more modern three-piece oil ring. It seems to be hard to find this particular combination. I can easily find 3/32 top rings with 3/16" oil rings. |
For piston rings check with Egge machine in California bedsides making pistons they are a good source for piston ring sets.
Ronnieroadster
I use the F word a lot no not that word these words Flathead, Focus and Finish "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 First Ford flathead roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH reset the record in 2024 to 211.830 running to mile four. Top speed 2024 mile five 220.672 exit speed 221.587 |
If it turns out that the 5/32 rings really are not available it is probably possible to skim out the ring grooves on a lathe and use the 3/16" rings.
contact David Reed at Auto Gas at 410-398-7340. They can supply any rings you need. Got the contact from Egge.
Yup,Otto. My bad
Might mention that with a modern three piece oil ring, a 4th ring is NOT needed in the lower groove. It is perfectly OK to leave that groove empty. There is an urban myth that says the 4th ring "stabilizes" the piston but that is "poppycock", nonsense, false, etc. Rings all float freely in their grooves so cannot support a piston in any way, shape, or form. All a 4rth ring does is add internal friction which reduces power.
Instead, the piston must support the rings at 90 degrees to the cylinder wall to maintain good ring seal. |
#9 | |
To paraphrase what was said above, "the piston supports the rings, not the other way around". |
I have a brand new set of Ross 3-ring 125 over pistons for a 4” crank for soneone who needs a set - pm me.
