Where should I start looking for a VIN number on my '29 Open Cab Pickup? ? ? Engine has a June '29 number.
Thanks in advance, Jerry |
It is on the top of the drivers side frame rail. Under the body and splash apron next to the body mount that is rivited to the frame.
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go?
The engine number was originally the VIN number. When the engine was installed the frame was stamped with the engine number on the top rail of the drivers side, about across from the battery area. the only way to see this number is with the body off, and many times there is to much rust/ pits to clearly see the number.
This is on my 29 AA CCPU see pics. This is on drivers side infront of firewall.
if you have a frame with unidentified numbers what are options to use the frame etc
#6 | |
When a new engine block was installed by a dealer it was expected that the dealer stamp the cars original number on the new engine block. |
You can buy reproduction Ford stamps on eBay.
