Old 07-01-2024, 12:08 AM   #1
40coe
40coe's Avatar
Default Rebuilding 1936 horn?
Wanting to rebuild my early horns. Does anyone have information on the capacitor value, point setting, etc.
40coe is offline   Reply With Quote
Old 07-01-2024, 12:20 AM   #2
highbeams
highbeams's Avatar
Default Re: Rebuilding 1936 horn?
all horns are the same 'til the early '50s. Even the long trumpet horns in the late '40s. The make-up is the same I've discovered 20+ years ago, using parts from a late '40s trumpet horn to replace parts in my '36 pickup horn. (dual '36 pickup horns; one was 'shot'.)
highbeams is offline   Reply With Quote
Old 07-01-2024, 07:38 AM   #3
Terry,OH
Terry,OH's Avatar
The points are normally closed with no power on the horn and open when the solenoid picks up. There is no setting suggest slowly adjust the set screw until you get the sound you want and then lock it down with the lock nut.
Old 07-02-2024, 01:54 PM   #4
40coe
40coe's Avatar
Good info, Thanks.
Still hoping someone has the information for capacitor and resistor values. For sure the capacitors need replacing.
Old 07-04-2024, 03:14 AM   #5
koates
Capacitor value on Ford Sparton horns is .2 mfd 400 volts. If it has a wire wound resistor instead of a capacitor then it should be 3 ohms. This information is out of the Sparton horn service manual. Most original horn capacitors by this time are faulty. I have repaired several horns and used new capacitors which make a big difference to the sound of the horns. Regards, Kevin.
koates is offline   Reply With Quote
