Hi all,
my Ford Model A Coupe is now nearly ready. What is missing now is an overdrive from a Volvo into my torque tube. Because I want to drive long distance on the highway. I got the tube and the J type overdrive from Laycock. I also do have a complete Volvo transmission from which I will take the shaft which drives the overdrive oil pump. My question would be if somebody did the job and does have detailed info on this. Is there a sealing required on the front plate to hold the oil inside? How to get the oil into the OD? Any info is welcome. Best regards from Germany Last edited by FlatheadV8Mike; 07-01-2024 at 02:12 PM. |
Here are the photos
