#21 |
>>Does anyone know how many miles to expect from the radials? I would think much more than bias tires.
You will get more miles from a hard compound which doesn't grip as well. Less from a soft compound which sticks to the road. |
#22 |
Here is Darla with her new Good Year Radials:
--------------------------------------- 1929 Model A Tudor - "Darla" '29 Model A: Old enough to start with a crank, young enough to steal the show! "Stay away from negative people, they have a problem for every solution" Model A Ford Club of America Model A Restorers Club Motor City A's Club |
#23 |
I got about 24k on a set of Coker Classic Radials on my 31 Town Sedan. I was running them at about 32 psi for the first 8k when I experienced some tube issues on the rear drivers side…flats. The tubes were scuffing in the tire. I increased the pressure to 35 psi and had one more flat. I increased the pressure to 38 psi and had no further issues during the last 12k miles of tire life. The car handling in high cross winds has greatly improved with the pressure at 38 psi.
#24 | |
![]() Quote:
I run mine at 35psig, no problems since. Last edited by Y-Blockhead; 07-02-2024 at 01:49 PM. |
