Old 06-14-2024, 02:41 PM   #34
ndnchf
ndnchf's Avatar
Default Re: Alternator that looks like a generator. Is there such a thing.
Sorry, but I do not have regulators. But most any quality 6 volt, 30-35 amp regulator should work. These are commonly used on vintage tractors also.
I normally just rebuild stock generators. I know others have built hybrids using 1955 and up 12 generator bodies with earlier flathead V8 parts. This is to get the 12v field coils. But this takes some extra work for the alignment and mount notches. Perhaps an easier alternative is to just install 12v field coils, then polarize for negative ground (assuming that is the configuration you plan to use.) The hardest part is removing and installing the pole shoe screws. I put together a rig for this using an arbor press. I have a video about this if anyone is interested. Changing to 12v fields works, but does not deliver the same max amperage as a true 12v generator. But is still sufficient for most uses.
I really believe for most applications, staying with the 6v positive ground system is the way to go. When properly done, the stock 6v system is just as reliable and starts just as well as a 12v system.
Steve
ndnchf is offline   Reply With Quote
