Old 06-08-2024, 11:41 AM   #1
rotorwrench
rotorwrench's Avatar
Default Re: Rear Diff Plug HELP
I'm a gas welder myself. I braze cast iron like that so that the banjo casting doesn't crack. It would heat the plug in the bore well enough for it to come loose. Heating and welding cast iron can be tricky. Concentrate heat on the plug as best you can. Let it cool slowly.
