Hello men!
Might seem simple to you but I'm kinda a newbie to the Model a world so here goes... The piece on the end of the horn rod (picture attached) ... gets installed at the 3 and 9 o'clock position or the 12 and 6 o'clock position? Methinks the 12 and 6 but not certain so the question. yes, horn rod is set on steering wheel with lever at 6 o'clock and yes, steering wheel is in the middle of its full travel. Thanks in advance ![]()
You thinks correctly, 12 - 6.
You could install it at the 3-9 position but then the light switch at the steering wheel would be at 3 or 9 o'clock.
For once methinks correctly!
Thank you kindly.
