Old 05-26-2024, 10:52 AM   #21
Y-Blockhead
Y-Blockhead's Avatar
Default Re: Electric Fuel Shut off
Originally Posted by katy View Post
If I was going to use the solenoid shut off valve I would put it under the dash, not in the engine compartment.
In a car with an indented firewall you don't have that option. Not to mention they fit a ¼" gas line.
BTW, the new ball valve shut off valves that Snyder's has work great. Finally someone improved the POS original type of valve. No leaks.
https://www.snydersantiqueauto.com/p...9339&cat=41707
Old 05-27-2024, 08:03 AM   #22
937footer
I had one on a 30 , worked fine until the summer temps and then started to be intermitant then totally failed on a tour . Took it off and trashed it . If you run one carry a 1/8 nipple fitting to remove it on road or another fuel line so when it fails your not stuck ,Learned my lesson and wont happen again.
937footer is offline   Reply With Quote
Old 05-27-2024, 08:54 AM   #23
gdmn852
gdmn852's Avatar
Hello again, with the indented firewall the electrical shut off is useful, to use the original you have to open the hood to turn it it on or off.Not that hard for long term storage, thank the state of New York for relocation of the shut off .
gdmn852 is offline   Reply With Quote
Old 05-27-2024, 09:26 AM   #24
katy
katy's Avatar
That's why the make/sell adaptors.
