Old 05-24-2024, 07:19 PM   #1
jtminor
Default Tail light connectore
Can someone please tell me how to connect these tail light wires.
jtminor is offline   Reply With Quote
Old 05-24-2024, 07:28 PM   #2
petehoovie
petehoovie's Avatar
Default Re: Tail light connectore
Old 05-24-2024, 07:58 PM   #3
cmbrucew
cmbrucew's Avatar
They look like aftermarket Fainstock bullets. They may plug into original Ford connectors.
Bruce
Works good
Lasts long time
cmbrucew is online now   Reply With Quote
Old 05-24-2024, 09:40 PM   #4
jtminor
anyone know where to get connectors
Old 05-24-2024, 11:41 PM   #5
restoman
Bob Drake had them recently, also probably Third generation.
restoman is offline   Reply With Quote
Old 05-25-2024, 07:33 AM   #6
tubman
tubman's Avatar
I will note that the "bullet" connectors shown look different from the original Ford units. They will probably work, but.....
Old 05-25-2024, 09:06 AM   #7
FortyNiner
FortyNiner's Avatar
Napaonline.com
Old 05-25-2024, 09:14 AM   #8
Kube
Kube's Avatar
Yep. They will work but you will need to grind down the diameter a bit. As is, they will not fit the connector.
Old 05-25-2024, 09:15 AM   #9
busmania
busmania's Avatar
I was able to get them to fit recently without grinding. They are just tight.
40 ford coupe Build -https://www.jalopyjournal.com/forum/...coupe.1277406/
busmania is offline   Reply With Quote
Old 05-25-2024, 04:28 PM   #10
JayChicago
JayChicago's Avatar
Aren’t those the light bulb contacts? Don’t look like bullet connectors. Wire looks correct for Ford taillight.
Old 05-25-2024, 04:34 PM   #11
vincent
They do look like the british Lucas connectors that were used on all british motorcycles between the 50s and 70s - should be easy to find.
vincent is offline   Reply With Quote
