Old 05-24-2024, 04:37 AM   #1
flathead 53
Default engine stumbles under load
just got finished converting my 53 f-100 to 12 volts , new distributor ,pertronix , new coil ,new wires ,plugs , truck starts right up and will idle fine bring RPMS up to 1500 engine starts to run rough and back fire , distributor is in correct as the timing ,, put new 94 carb on engine ,still the same put another carb on ,still the same , lost on what to try next , truck ran fine before 12 volt conversion , Help.
flathead 53 is offline   Reply With Quote
Old 05-24-2024, 05:49 AM   #2
38 coupe
38 coupe's Avatar
Default Re: engine stumbles under load
I would start by putting the good distributor back in. Measure the resistance of the new coil and add a ballast resistor if needed to get the total resistance where it needs to be. Condenser and points do not need changing for 12V. I am a very big advocate of "if it ain't broke, don't fix it" (learned the hard way multiple times).
Old 05-24-2024, 06:57 AM   #3
jimvette59
jimvette59's Avatar
If you do not have a ballast resister install one and or check the coil to see if it has a resister in it or not. JMO
jimvette59 is offline   Reply With Quote
Old 05-24-2024, 07:24 AM   #4
glennpm
glennpm's Avatar
For a 12 V system you'll want to target about 4 ohms total resistance, sum of the coil's primary resistance plus an external ballast resistor.
Glenn
Archives of historical but relevant older articles:
Hover mouse over the links below and click!
Rumble Seat's Notes
Techno-Source for the 1932 thru 1953 Flathead Ford
Old 05-24-2024, 08:09 AM   #5
JayChicago
JayChicago's Avatar
I think you meant to say target 4 amps. You get to that by having about 3 ohm total resistance in the primary circuit.
I = V/R
4 amp=12 Volt / 3 ohm
Old 05-24-2024, 09:31 AM   #6
deuce_roadster
deuce_roadster's Avatar
I have never used a "pertronix" but do they even need a resistor? There are no points to burn up. I have heard the electronic distributors don't play well with generators as they like a stable voltage that doesn't vary. I will stick to points and condensers and 6v on my flatheads. When everything is "right" 6v works fine and reliable.
Old 05-24-2024, 09:35 AM   #7
glennpm
glennpm's Avatar
No, looking for about 3 amps so the points will last longer This is from a recent post I made:
"I had a running and starting issue this week so I'm replacing my Petronix II with a Bob Drake rebuilt 1942 crab distributor on my 59AB. I'm planning to add a ceramic 1.5 ohm inline with the coil's primary resistance of 2.3 ohm. I have a 12v negative ground wiring system.
Running resistance = 2.3 + 1.5 = 3.8 ohm
Ohm's Law I = V/R
I = ~12v/3.8 = ~3.3 amps
For starting I want to add a push button momentary switch so the coil will see about 5.5 amps when the ceramic 1.5a resistor is bypassed."
Rumble Seat's Notes
Old 05-24-2024, 12:43 PM   #8
JayChicago
JayChicago's Avatar
Glennpm
All of that makes perfect sense. Good logic there. If that coil is putting out good spark at lower amps, that’s all you need.
Old 05-24-2024, 01:06 PM   #9
Ggmac
Is your new distributor only mechanical advance ? If so read the instructions on adjusting the advance curve . Or CAREFULLY after you start it , bring it up to where it starts stumbling and wuth the distributorclamp a LITTLE loose , rotate it A LITTLE. See if the stumble improves
Old 05-24-2024, 04:16 PM   #10
glennpm
glennpm's Avatar
Just took it out for a short test ride and it is working great, great power, no pings all is wonderful! Tomorrow may be a different story :-)
Thanks for the tip Ggmac and yes it is now back to stock mechanical.
Glenn
Rumble Seat's Notes
Old 05-24-2024, 07:20 PM   #11
flathead 53
thanks, distributor has vac and mech advance , does not require A resister ,tried A mallory distributor before the pertronix, sent the mallory back to speedway same problem. Using A pertronix flame thrower 40,000 out put coil .
Old 05-24-2024, 09:11 PM   #12
drolston
drolston's Avatar
Some dark night take a look under the hood while you jazz the throttle up and down. If you see sparks jumping anywhere around the coil, plugs or ignition cables, you might want to replace that flamethrower with something a little less intense. Our 7mm cables do not insulate as well as the usual 9mm cables.
Old 05-24-2024, 09:55 PM   #13
Bill OH
The stock vaccum distributor ran rough and did for me the very thing you describe. (To much advance because of the high vaccum) Mechanical advance solved the problem. Packard 440 Ignition wires are very reliable.
Bill OH is offline   Reply With Quote
Old 05-25-2024, 07:27 AM   #14
tubman
tubman's Avatar
I had a MSD "Ready to Run" distributor on an 8BA and it had too much advance (Chevy Curve). I went back to a mechanical only Mallory and have been very satisfied. Although the major car manufacturers seem to know how to make electronic ignitions, it seems the aftermarket is having problems.
