Does anyone know of reproduction or have an original set of side gate hindges for the early Ford stake beds.
Might check on the AA site. http://forums.aa-fords.com/
#3 | |
![]() Quote:
I saw some in a welding equipment store that looked about right. Newc
there registration is f up.
Could you modify these to make what you need?
https://www.buyersproducts.com/produ...nector-set-753 |
Check Tractor Supply, Bigger Ace hardware stores. I built a stake bed box many years ago and found the hardware at those stores. Also every year when I go to the LARS and am driving around mostly Pomona I see all these stake bed trucks with similar black powder coated hardware?
#9 | |
![]() Quote:
i could. Would like to have one piece to copy.
they would work, for sure. Thats what my fathers rack truck had.
The Model AA truck parts didn't change through the Early Ford V8 era. To help in looking for parts, the part numbers for the hinges are AA-186304-B and AA-186405-B. You need a total of 8 of each type.
Northern Classis Trucks, now out of business, used to make these parts. I don't know of any current supplier of the hinge brackets. I can make an accurate drawing from a couple of original hinge brackets and send to you if that will help. Attached is a picture of the two types needed.
1935 157" 1 1/2 ton stake truck undergoing full original restoration 1936 131 1/2" panel truck rescue preservation Author of the 1935-1936 Ford Model 51 V8 Truck book published by the Early Ford V8 Club of America |
#13 | |
![]() Quote:
