05-01-2024, 12:56 PM | #1 |
Old brazed repairs on a 21 stud
Hi,
I'm tearing down this old block that's been out of service a long long time apparently. Everything looks pretty good inside, bearings are actually pretty nice, nothing was too loose or floppy, Flat top pistons .060, ford rods, one cylinder's valves are pretty tarry like it was smoking pretty bad and it's got a lot of that old goop in the pan from oil additives to try to control those kind of smoking engine issues. Then there's these old repairs. What do you think, worth the effort to put it back together, or just scrap it out. I bought it for $100 to get the crank pulley and heads and stuff off of it and whatever else was salvageable. Thanks! |
05-01-2024, 01:50 PM | #2 | |
Re: Old brazed repairs on a 21 stud
05-01-2024, 02:41 PM | #3 |
A good cleaning and pressure testing would be the starting point for me BEFORE you ask the questions you just asked.....Pressure testing "might" answer a lot "before" you even have to ask. JMO
05-01-2024, 02:45 PM | #4 |
Me, I'd probably grind down into the brass a bit and see how deep it goes. When there are cracks like that, you can almost be assured they go down into/below the hardened valve seat. The right process is to remove the valve seat and see how far the cracks go - then determine whether or not they can be "pinned" with confidence. Pinning involves the drilling, tapping and installation of Iron-Tite or Lock-n-Stitch type iron plugs. If you have never done it, is a good idea to bring the block to somebody who has done a lot of it.
Also, you will have to sleeve both cylinders - as the cracks will end up in the bores as well. In the end, you'll have to sink some $$$ into it . . . and I'd start with exploring these old "fixes" and also having the whole block magged and pressure tested. There can be other cracks you don't yet know about. What year is the block? |
05-01-2024, 03:28 PM | #5 |
It's a 35 or 36 block, babbitt bearings not inserts. I'll probably have a little bit of test done on it, I always hate to throw a block away if it can be saved, Ford's not making them anymore, right?
05-01-2024, 04:03 PM | #6 |
05-01-2024, 04:18 PM | #7 |
Oh, I'm gonna pressure wash the heck out of it after I pull the valves today for sure. Then it'll go over to Harrell Engines LA & Alec can take a look at it, he's a real good guy to know in the flathead world in SoCal.
05-01-2024, 05:21 PM | #8 |
Pressure test it and run it. So long as it passes pressure test and you don’t want to go long trips. Run it. I think that’s freaking awesome. I have to say I am incredibly talented with an Oxy Acetylene torch to include some massive cheated race parts many moons back so trust me who ever did that knew what they were doing. Will it be successful? I have no idea. As I said I can braise damn good and I wouldn’t do that. BUT you have nothing to lose go for it. It may ruin fine forever.
05-01-2024, 06:23 PM | #9 |
It appears to have been running a while after the repairs . Assuming no new cracks , I’d clean it rering it and run it .
05-01-2024, 07:25 PM | #10 |
Lol, yeah I’ve done some magic with braze and flux too always fun.
05-02-2024, 11:50 AM | #11 |
One thing I learned about brazing cast iron is that it will stay more structurally sound in the joint if the brass overlaps the crack. It needs a blanket coating to help it stay attached. I've none this when brazing old motorcycle parts such as cylinder base attach stud holes. I machine it down a bit but leave enough blanket to keep it together. As was mentioned, a pressure test will tell if the joints are still good or if they ever were. Brazing like that can work but for how long is the question. Till it overheats again is the best answer. I'd be concerned about hardened seat retention in the pockets so a person would have to look it over pretty good before putting a lot of work or money into it. The more repairs there are, the better the chance of failure.
