04-22-2024, 11:04 PM | #1 |
Lincoln pinion backlash
I'm in the process of setting up a Lincoln [hypoid] rear end. I'm quite familiar with how to set up a banjo rear, having done numerous Fords over the years, but I don't know the specs for backlash between ring and pinion for a Lincoln. Does anyone have the specs? [measured at the spline]. Thank you!
04-23-2024, 12:48 PM | #2 |
Re: Lincoln pinion backlash
I have it written down with other notes and bearing and pinion seal number from when I rebuilt my 39 Zephyr rear axle. . I’m away from the shop now but maybe later this afternoon.
04-24-2024, 04:18 PM | #3 |
Think those parts came as an assembled pinion/ housing and ring gear so no specs were published. At least none ive been able to find. I would say tooth contact pattern is more important than lash with those
05-02-2024, 02:59 PM | #4 |
I finally found the information I was looking for.
05-02-2024, 05:04 PM | #5 |
05-02-2024, 09:13 PM | #6 |
05-02-2024, 11:38 PM | #7 |
I've finally located the data I was searching for.
