03-21-2024, 10:49 PM | #1 |
model A airplane carburetor?
found this in a box of model A parts i got. for airplane engine?
03-22-2024, 08:21 AM | #2 |
Re: model A airplane carburetor?
Yes, I believe so.
See original page number 1772b (file page n39) of the magazine "Aviation Week" in the link below. They refer to fitting a Stromberg NA-R3 carburetor (same as the data plate on your carb) to an airplane engine being developed by a company in Lansing, MI. https://archive.org/details/Aviation...p?view=theater Your intake manifold looks like it is the correct dimensions to fit a stock Model A engine block. Very cool.
03-22-2024, 09:00 AM | #3 |
The manifold "hot spot" seems to agree with the Model A dimension (slightly higher than the centerline of the exhaust ports) but I'm not sure a Model A exhaust manifold would be the manifold of choice for a Pietenpol.
The intake manifold may sit "closer" and fastened "to" the hot engine block than Model A design. Copper IS a possibility, as is the Marvel Mystery Oil shroud. Joe K
Shudda kept the horse. Last edited by Joe K; 03-22-2024 at 09:06 AM. |
03-22-2024, 10:10 AM | #4 |
The Stromberg-Bendix NR-A series of carburetors was common in the early years of aviation. The NA-R3 would have been one of the smallest of the type produced that still had a manual mixture control. Engines like the Continental A40 and A50 might have used it. The Lycoming O-145 and Franklin 4AC 150 are other candidates. The Continental A65 engines had a 4-bolt carb flange.
Marvel-Schebler pretty much took over the small aviation carb business in the modern era. |
03-22-2024, 10:27 AM | #5 |
Not to sidetrack things but, I do like that valve chamber side cover in the above photo
03-22-2024, 10:34 AM | #6 |
03-22-2024, 10:55 AM | #7 |
The oiling modifications by Bernard Pietenpol were extensive to get full pressure to the mains. The original oil return from the side was deleted so all it needed was a plain cover plate. That one was likely milled out of aluminum plate. The magneto installation was another big mod but I don't know if the mag he used is all that common. TCM-Bendix or Slick type mags are about all that is available now days.
