Ronnieroadster
SO I have the later pump and pick up going in, I shouldn't worry too much about the tray missing completely??? |
#2 | |
![]() Quote:
You will experience lowered oil pressure going up hills and around corners. My most recent experience was one with a '34 coupe. The owner had installed an 80# pump completely removing the pan baffle. Guess what? Yep, low oil pressure at times. Installed as much of the formerly removed baffle and the oil pressure issue was resolved permanently. Do it once, do it correctly.
Michael
That's what I am afraid of....I don't want to take any chances. NOW the issue is with mine completely missing either getting a whole new pan OR figuring out how to make one and install it??? AND Having one made similar to stock with NO example to copy |
#4 | |
![]() Quote:
Two pieces of sheet metal maybe 2" in height tack welded to the side of the pan (one each side) and long enough to get close to the sump. You want to keep the sheet metal off the bottom of the pan about 1/4" or so.
#5 | |
![]() Quote:
I looked back at on old post and found a posted copy out of a manual of the exploded view of the pan and tray from a past post....I will most likely fab one up out of card board first before I start cutting sheet metal and welding!!! Thanks. |
#7 | |
![]() Quote:
Now if you decide to go off roading maybe the oil in the pan may for a split second get away from the pickup but I doubt you will ever experience anything that will cause such issues! So overall its YOUR call. Use the latter pump it will work perfectly. Ronnieroadster
I use the F word a lot no not that word these words Flathead, Focus and Finish "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 First Ford flathead roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH reset the record in 2024 to 211.830 running to mile four. Top speed 2024 mile five 220.672 exit speed 221.587 |
