02-26-2024, 12:10 PM | #1 |
rotor cap
the gap between the rotor cap and the distributor cap is about .036 instead of .025. How can I adjust the gap to make it smaller?
02-26-2024, 12:57 PM | #2 |
Re: rotor cap
Bend rotor
www.whidbeymodelaclub.com |
02-26-2024, 05:34 PM | #3 |
Re: rotor cap
Ive found the current repro distributor bodies have slightly short contacts. This makes it hard or impossible to get a .025" gap no matter how you bend the rotor.
02-26-2024, 06:19 PM | #4 |
Re: rotor cap
I've soldered a piece of brass to the end of the rotor, then adjusted the gap to 0.025". It didn't make much (if any) difference.
I'm part of the only ever generation with an analogue childhood and a digital adulthood. Last edited by Synchro909; 02-29-2024 at 07:43 PM. |
02-26-2024, 06:58 PM | #5 |
Re: rotor cap
Normally you can bend the tab up. It helps to have the rotor out of the distributor when you do this.
My experience with the rotor gap has been different than Synchro. This may be because my ignition was marginal but the smaller the gap the better my car ran. If you want to set the gap smaller than 0.025, just make sure that it does not hit any of the pins on the inside of the distributor body. Sometimes the distributor body can be loose on the distributor and move to close up the gap in one are and open it up in another area. More: The higher the pressure the harder it is for the spark to jump the gap. So in a high compression engine more voltage is needed for the spark to jump the spark plug gap. What does this have to do with the rotor gap? Maybe nothing, but I contend that a smaller gap at the rotor will provide more voltage at the plug.
A is for apple, green as the sky. Step on the gas, for tomorrow I die. Forget the brakes, they really don't work. The clutch always sticks, and starts with a jerk. My car grows red hair, and flies through the air. Driving's a blast, a blast from the past. Last edited by nkaminar; 02-28-2024 at 08:40 AM. |
02-26-2024, 08:06 PM | #6 |
Re: rotor cap
02-26-2024, 08:14 PM | #7 |
Re: rotor cap
Ditto on the breaking. I believe the original rotors used brass contact, repros are steel.
02-26-2024, 08:40 PM | #8 |
Re: rotor cap
Are you having issues ? .036 shouldn’t be a big issue, in fact it may give you a hotter spark , some here will disagree BUT do an Internet search for spark intensifiers , that will back me up
02-26-2024, 11:41 PM | #9 | |
Re: rotor cap
.036 should not be a problem at all. Will give you a hotter spark. We would make a spark intensifier by making an adaptor with a built-in gap if we had an issue with an old engine that wanted to oil foul a plug. Worked great. Chris W |
02-28-2024, 01:31 AM | #10 |
Re: rotor cap
I’ve never been able to bend the rotor without breaking it. Nor have I ever achieved the recommended 0.25. I gave up, and in 60+ years of driving Model A’s I’ve never noticed any trouble with this issue.
02-28-2024, 07:24 AM | #11 |
Re: rotor cap
I believe it can be bent with a good bench vice and needle nose pliers...but I agree with Big Hammer, post #8.
If I recall correctly, I've read a post somewhere that there is a book on Model A's with a title "Secrets of Speed" which suggests .010 on the gap. On our car, the distributor bodies are a loose fit. Again, if I recall correctly, 3 or 4 pieces of thin electrical tape placed vertically and distributed evenly around the body can serve to tighten the fit????? I haven't tried it. I'm thinkin' that a too loose gap will add heat to the coil????
"It ain't what you know for certain that gets ya in trouble. It's what ya know for certain that just ain't so!" |
02-28-2024, 12:14 PM | #12 |
Re: rotor cap
This slide may help you.
Bob Bidonde |
02-28-2024, 01:13 PM | #13 |
Re: rotor cap
Bob Bidonde - Why is the Brass part of the Rotor Cap in you illustration rounded? Is this a New Mod or........?
I don't care if the "A" Starts BUT sure WANT IT TO STOP! |
02-28-2024, 09:10 PM | #14 |
Re: rotor cap
Where did the .025 gap specification come from??
The only specifications from the era thatI have found is .005” in a radio installation instructions article— that said to reduce it to create less interference, nothing in Ford literature though. |
02-29-2024, 10:30 AM | #15 |
Re: rotor cap
The infamous "Red Book", page 1-101, Rotor to body terminal gap .025". Also page 1-107
If you don't hear a rumor by 10 AM, start one!. Got my education out behind the barn! Last edited by katy; 02-29-2024 at 10:31 AM. Reason: Addition |
02-29-2024, 11:09 AM | #16 |
Re: rotor cap
Cape Coder,
The brass distributor on the rotor is rounded with a curvature compatible with the inside diameter of the distributor body. Kurt In New Jersey, I think the 0.025" gap is an opinion of Model A experts. I however, use 0.015" because the smaller the rotor gap is, the lower the impedances to the spark plugs are, so the sparks have more intensity.
Bob Bidonde Last edited by Bob Bidonde; 02-29-2024 at 11:29 AM. |
02-29-2024, 01:25 PM | #17 |
Re: rotor cap
Bob, you get an A+++ for all your helpful illustrations. THANK YOU!
02-29-2024, 07:13 PM | #18 |
Re: rotor cap
A larger rotor gap works to fire fouled plugs better, a bandaid for improper mixture same as all the playing with sparkplug heat ranges to cure the black carbon from too rich of a mixture.
It takes more spark voltage to jump all the gaps, at higher speeds the coil voltage is reduced , So other than the “red book”( I don’t have one) where is the .025 rotor gap specification listed, Ford blueprint? The later production new Ford parts in my car had a .010 gap average on my car. |
