Old 02-25-2024, 06:40 AM   #1
brokenspoke
Default Re: Rotor position at TDC
Originally Posted by y-blockhead View Post
nope. The slot on the bottom of the distributor is offset. The distributor will only drop down into the slot in one position. If he is 180° off he will have to loosen the rotor and turn just the rotor 180° to line up with tdc on #1 compression stroke. No need to lift the distributor.
bingo
brokenspoke is offline   Reply With Quote
