It makes a difference whether the car is 1940 and earlier or '41-'48. The later cars have the mounting points higher relative to the frame than the pre-'41's.
#2 | |
![]() Quote:
The chassis has mounts set up for the 8RT. I suppose the flanges on the earlier pumps being lower wouldn't be the end of the world in this case as the transmission is a T5 and not a stock mount type. Might be enough to cause a firewall clearance issue, though, due to the tilt that would be induced.
Mike Wanted: - '32-34 Open Cab Pickup (RPU) parts and documents/articles/info - ARDUN parts |
#3 | |
![]() Quote:
Not a big deal at all. Easy enough to make spacers if you need it up higher. If you need it lower, a trick is to use '49-'50 Merc pumps. The mounting arm sits the motor lower than the 8BA/8RT pumps. Tim |
