Old 02-16-2024, 09:15 AM   #1
50Trucking
Default Motor stand adapter for Model A engine
Are there any good how to designs to make an adapter to hold the model A engine? This is my first tear down of an A engine and it looks like I need to bolt it up twice. Once at the flywheel housing and at the water passage on the side of the block maybe?
50Trucking is offline   Reply With Quote
Old 02-16-2024, 09:28 AM   #2
oldspert
oldspert's Avatar
Default Re: Motor stand adapter for Model A engine
Most of the parts dealers have a ready made engine holder that fits a generic engine stand. Cost is usually around $110 but well worth it. Bolts to the water inlet side and secures at the oil pan rail.
oldspert is offline   Reply With Quote
Old 02-16-2024, 11:05 AM   #3
JayJay
The four adjustable arms that come with your engine stand will work for the flywheel side, but you may need to make some tubular spacers and use longer bolts to get around the crankshaft end once the flywheel housing is removed. As oldspert says, easiest thing for the water inlet side is to use the adapter sold by the vendors, see for example https://www.snydersantiqueauto.com/p...8613&cat=41910. Others have come up with their own variations for this using angle iron, do a search on this forum to see what they’ve come up with.
If you use the commercial product you won’t need to grab it at the flywheel end, which takes care of that issue.
JayJay
San Francisco Bay Area
1930 Murray Town Sedan
1931 Briggs S/W Town Sedan
Old 02-16-2024, 02:45 PM   #4
nkaminar
nkaminar's Avatar
The threaded holes where the water inlet is are strong enough to hold an engine. Use grade 5 bolts and make sure they bottom out in the holes. Add washers if necessary to make the bolts fit tight.
Use some tack welds to keep the arms that are supplied with the stand from moving. You can grind off the tack welds if you want to use the stand for a modern engine.
Old 02-16-2024, 03:54 PM   #5
Joe K
Joe K's Avatar
Looks just about like mine. One wants to be careful when "swinging" the engine around the stand-off. Depending on the configuration at the time it may be off-balance. Have two people available when releasing the pivot.
I always kind of liked the engine stand in Victor Page's Model A book - it has the advantage of a "gear" rotation. But it suffers from "two rails" and impeded access. There is no perfect engine stand.
Joe K
Shudda kept the horse.
Old 02-16-2024, 04:46 PM   #6
Gene F
Gene F's Avatar
How stable is that? I have the stand with 4 wheels.
Old 02-16-2024, 06:03 PM   #7
Ruth
Closer to $180 these days.
Ruth
Old 02-16-2024, 09:06 PM   #8
JayJay
Quite stable. As long as the engine doesn’t extend its center of mass past the front wheels (which it doesn’t, at least on mine - Harbor Fright 1000 lb) then you are golden. Seems to me that my extensions are about 3-1/2 inches or so, but don’t quote me on that. Those are to bolt to the block without the flywheel housing. And of course, without the flywheel.
JayJay
Old 02-18-2024, 02:23 PM   #9
Gene F
Gene F's Avatar
Like some sections of old pipe to sleve the bolts?
Old 02-18-2024, 08:32 PM   #10
JayJay
Gene - pipe would work. I took some 1” cold rolled and drilled down the center on the lathe. If it’s worth doing, it’s worth overdoing. Don’t have the setup close, but my recollection is that took 7/16” bolts to screw onto the block. I don’t remember whether those are coarse or fine thread.
JayJay
Old 02-18-2024, 09:00 PM   #11
Martinbuilt
I bought one from snyders, although it seemed like a lot to spend.
No regrets, though. It's very solid, and allows you to spin the motor nose down, which makes hanging the flywheel much easier.
Also, there are two pins that engage a couple pan mounting holes in the block. The water neck bolts are strong, but I like having 4 mounting points
Martinbuilt is offline   Reply With Quote
Old 02-19-2024, 12:01 AM   #12
CarlG
CarlG's Avatar
Just a hint: On mine, I drilled and tapped a couple of holes in order to have a place to store the bolts I use to bolt the adapter to the engine, that way I don't have to turn my shop upside down looking for the bolts when I need to use it again.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 02-19-2024, 03:55 PM   #13
California Travieso
Send a message via Yahoo to California Travieso
You can use the “search this Forum” tool in the upper right hand corner. Search for “engine stand adapter” and you will find many discussions that include how to make your own adapter.
David Serrano
California Travieso is online now   Reply With Quote
Old 02-20-2024, 03:58 PM   #14
Dan McEachern
Just FYI for you guys on engine stand adapters. The KRW stands have the engine pretty well balanced. The center of rotation on a KRW stand adapter is 7" from the bellhousing surface and about 4 1/4" from the pan rail. If you are going to make one, I'm pretty happy with that balance point.
Dan McEachern is offline   Reply With Quote
Old 02-20-2024, 09:07 PM   #15
katy
katy's Avatar
Originally Posted by Joe K View Post
One wants to be careful when "swinging" the engine around the stand-off. Depending on the configuration at the time it may be off-balance. Have two people available when releasing the pivot. Joe K
That's one of the reasons why I put a worm drive reduction gear on my engine stand.
Old 02-21-2024, 11:15 PM   #16
50Trucking
They want 185.00 now and i feel i can make one for less. Just wandering what others have done
Old 02-22-2024, 12:48 PM   #17
California Travieso
Use the “search this Forum” tool.
David Serrano
