Old 01-06-2024, 12:48 PM   #1
Jim Brierley
Default Re: Rod alignment
Interesting story Pete, and very true. If the guy had babbitted the Pontiacs, as most did, they should have been straight when the babbitt was cut.
I don't know if you knew Wes Cooper? I was at his shop one day when he was building B engine using Pontiac rods, he simply used Pontiac inserts with another, different, insert inside of the Pontiacs. Not the way I would recommend, but I guess it worked. I've also seen him lighten valves by just using a common bench grinder, with just holding the valve head against the wheel. For some reason he had a pretty good reputation as an engine builder, he specialized on Cragars.
Old 01-06-2024, 02:53 PM   #2
Pete
I didn't know Wes but had heard of him. I can understand lightening valves on a bench grinder. I ground my first cam on a bench grinder when I was in high school. It was faster than my friend's Winfield in the same engine.
Old 01-07-2024, 01:28 PM   #3
Jim Brierley
A friend ground a cam on a lawn mower sharpener, it ran pretty well but had more lift but not much more duration.
