Can I use bulk resistance modern style spark plug wire to replace the old solid wire spark plug wires that were in my truck when I got it? Will the original coil work for this?
1946 Ford 1-1/2 ton truck. 6 Cylinder "G" engine. |
Sure , we do it all the time with bulk wire either resistance or solid wire etc.......
Thanks! That saves me a little cash since I have spool of ignition wire that would be laying around gathering dust otherwise.
What are the good points of packard wires vs modern spark plug wire?
I am a believer |
I wouldn't use carbon resistance wire, --too much work for it's lifespan, but the wire wound stuff can last a long time.
If it would have been a snake it would have bit ya! i can't spell my way out of a paper bag! |
Yup. Worked great.
Brendan, Yes resistance wires were developed for radio static. Not really an issue to me because my truck doesn't have a radio. The reason I went with resistance wires was because I had a box of resistance wire, boots, and ends that were on the shelf of my shop when I bought the place. Saved me some money. |
In modern cars ,This resistant wire is a source of engine mis when its bent or old
i used the generic speedway kit for flatheads and it worked well it was spiral wound
