Old 12-31-2023, 03:49 PM   #1
Roger W Gerow
Default Sun Visors
I have a big smile on my face every time I drive my 1951 Ford coupe. He have lots of sunny days here. Only one problem. The left and right sun visors don't stay up very well. Is there a way to tighten them up to prevent them from coming down? HELP!
DD658
Roger W Gerow is offline   Reply With Quote
Old 12-31-2023, 06:27 PM   #2
325w
Default Re: Sun Visors
Could be a screw at the mount end to tighten. Then it could be sheet metal and you might cruse it a bit more to tighten. On some newer visors they had plastic sleeve. A bit of heat can distort the plastic an make it tighter.
325w is offline   Reply With Quote
Old 12-31-2023, 06:29 PM   #3
Roger W Gerow
Thanks, I'll take a closer look and see if that will do it.
DD658
Old 12-31-2023, 07:18 PM   #4
paul2748
paul2748's Avatar
If it's just the visor part and not the rod that is moving, bend the rod a tiny bit to make a tighter connection
48 Ford Conv
56 Tbird
54 Ford Victoria
