Old 11-24-2023, 07:25 PM   #1
47topless
47topless's Avatar
Default Claim of 25% HP bump true?
Just purchased a nice '31 Victoria. My first "running" Model A. Long in FH Ford V8's.
Going through a local Dealer's parts catalogue, I noticed a claim of gaining 25% HP with their milled, high compression head. While I do not question the integrity of this company, or this offering, it seems too damned easy!
Can the increased compression, achieved in such a simple way, really bump the HP to that incredible degree?
Phil
47topless is offline   Reply With Quote
Old 11-24-2023, 07:44 PM   #2
Y-Blockhead
Y-Blockhead's Avatar
Default Re: Claim of 25% HP bump true?
Well, when you are starting with the mighty 40hp... 10% is only a 4hp increase.
Old 11-24-2023, 07:59 PM   #3
Marshall V. Daut
Consider that the 1932 Model B four-cylinder engine was basically a beefed-up Model A engine. The main differences - aside from a large journal crankshaft that was later counterbalanced - the Model B engine featured a slightly more aggressive camshaft, a larger CFM carburetor with a wider intake manifold and a 4.6:1 cylinder head. That 4.6:1 ratio is only slightly more aggressive than the Model A's 4.2. This engine was rated at 50 horsepower, meaning 10 more than the Model A. That equates to a 25% increase in horsepower. Sound familiar?
The "high compression" cylinder heads being produced today for Model A's and B's are at least 5.0:1. A couple are 6.0 and some even 7.0+. It's not just the compression ratio that makes the extra horsepower. It is also the design of the head's combustion chambers that creates the right turbulence and spark travel that help improve performance. These heads will definitely increase horsepower AND torque. I should think that the 5.0 head might not supply the extra 25% increase (10 HP), but the 6.0 and above heads will give a closer approximation. If the advertised head is one of the heads I described with at least 6.0:1 CR, the horsepower improvement claim is in the ballpark with a little fudge factor allowed.
Marshall
Marshall V. Daut is offline   Reply With Quote
Old 11-24-2023, 08:17 PM   #4
Ernie Vitucci
Ernie Vitucci's Avatar
Good Evening...Ad a Model B intake and Carburetor and the 5.0 head or higher and you will be right on the edge of 50 HP. Ernie in Arizona
Ernie Vitucci is online now   Reply With Quote
Old 11-25-2023, 07:57 AM   #5
Bob Bidonde
Bob Bidonde's Avatar
I run 5.5:1 and 6:1 compression cylinder heads on my Model A's. The stock looking 6:1 cast iron cylinder head currently available is the way to go. I notice more power & torque and much better gas mileage.
Bob Bidonde
Old 11-25-2023, 08:24 AM   #6
mach0415
mach0415's Avatar
I noticed a significant torque increase with my 6.5:1 Snyder’s cylinder head. I also went with a Vortex dual updraft intake. I’m satisfied with my ‘28’s performance. Everyone commenting in the increase is correct. Even 10hp more is very noticeable.
Thanks,
Mark in SC
"We the unwilling, led by the unknowing, are doing the impossible for the ungrateful." -- By society, who is still arguing over who said it.
mach0415 is offline   Reply With Quote
Old 11-25-2023, 01:47 PM   #7
Jim Brierley
The quickest, easiest and cheapest way to more HP on the Model A is to increase compression and add a larger carb. The results will amaze you!
Old 11-25-2023, 05:50 PM   #8
Synchro909
Synchro909's Avatar
Originally Posted by jim brierley View Post
the quickest, easiest and cheapest way to more hp on the model a is to increase compression and add a larger carb. The results will amaze you!
x2!
Even at my age, I still like to look at a young, attractive woman but I can't really remember why.
Old 11-25-2023, 08:02 PM   #9
47topless
47topless's Avatar
...and that settles that! Check please."
Old 11-26-2023, 11:13 AM   #10
Rob Doe
Jim Brierley, post #7,
Would a Model B carb and a machined out intake be a good choice?
"It ain't what you know for certain that gets ya in trouble. It's what ya know for certain that just ain't so!"
Rob Doe is offline   Reply With Quote
Old 11-26-2023, 11:36 AM   #11
brito36
With all the conversations on increased compression, larger carburetors, and intake manifolds, I would make sure that my lower end could handle all these improvements.
brito36 is offline   Reply With Quote
Old 11-26-2023, 01:02 PM   #12
47topless
47topless's Avatar
Thumbs up Re: Claim of 25% HP bump true?
Good suggestion. I'll start the Imodium right now.
But seriously, how would a person go about testing the integrity of the lower end engine components?
Thank you,
Phil
Old 11-26-2023, 02:13 PM   #13
Dodge
Rob Doe,
Yes, its done all the time. If your going to run a B carb you need either a B manifold
or a bored out Model A manifold. The B manifold sets the carb at a different angle but can be corrected with ovaling the holes in the manifold out or using smaller bolts.
Dodge is offline   Reply With Quote
Old 11-26-2023, 04:10 PM   #14
Synchro909
Synchro909's Avatar
Originally Posted by Dodge View Post
Rob Doe,
Live and learn. I didn't know that. It might explain why my B carburettor cuts out when braking to a stop. The problem with a RHD car is the lug on the intake manifold for the ignition advance mechanism which is present on an A manifold but missing on a B because they supposedly had automatic advance in the distributor.
I am guessing here but does the change lower the intake or raise it. Details would be very welcome.
Old 11-26-2023, 11:03 PM   #15
Dodge
The difference is the carburetor sitting at a different angle side to side not front to back or up and down.
Your carb cutting out might be fuel shoshing, might be float level.
Old 11-27-2023, 01:03 AM   #16
1928 Sport Coupe
1928 Sport Coupe's Avatar
I would like to install a High Compression head in either 5.5:1 or 6:1 such as Snyders, a "B" cam, a "B" carb, and a bored out "A" intake. If I were to use new poured Babbitt mains and rods would that be sufficient for the improvements I want to do? Which head would be the better choice, the 5.5:1 or 6:1? I have been told any HC head could destroy the center main bearing if you drive it at all aggressively. I would just like to be able to keep up with traffic when needed.
As far as I know this is the original 35K miles engine in the car (1930 Town Sedan) and I would like to keep it in the car. This way I could always return it to stock.
Thanks
1928 Sport Coupe is offline   Reply With Quote
Old 11-27-2023, 08:48 AM   #17
AzBob
Old wives tale about a 5.5:1 or 6:1 high compression head taking out the bearings. I run a 6:1 Snyders head and get better mileage more power and a cooler running engine.
AzBob is online now   Reply With Quote
Old 11-27-2023, 12:12 PM   #18
Jim Brierley
Of course it would but a 2-throat downdraft would be better.
Old 11-27-2023, 12:15 PM   #19
Jim Brierley
Always a good idea, I have always run Model B engines, and they are strong, bigger bearings and better oiling system, but A engines are very strong and reliable too.
Old 11-27-2023, 12:25 PM   #20
Jim Brierley
Thanks
Higher compression and other things that make more power CAN be harder on bearings, BUT don't if you ease back on the ignition timing a bit, which does 2 things. 1) it prevents detonation and 2) is needed because the fuel will be burning faster so is more apt to knock (detonate) Also, driving down the road takes exactly as much power with or without more power, so most driving will not affect the babbitt or anything else.
