11-14-2023, 12:43 PM | #1 |
21 Stud Pressure Testing Plate W/Gasket
City:
Sparks
State:
Nevada
Price:
$250
I'm taking orders to have a few 21 stud pressure testing plates made. These are invaluable for locating an engine issue, either in the cylinder head, or block. The plate is 1/2", with a 1/4" sealing gasket, both 100% accurate by scanning, and water jetted. I'm not supplying any block off plates, as 32-36 is different to 37 center outlets. If interested, text or call Doug 775-219-8241. Price will be $250 each.
A plate is already available for the 24 stud engine from Speedway, but the plate is only 3/8" thick, and costs $279. There are NO 21 STUD PRESSURE CHECKING PLATES CURRENTLY AVAILABLE!! (I just discovered a small pin hole in a combustion chamber, which saved me from pulling the engine) |
11-17-2023, 11:22 AM | #2 |
Re: 21 Stud Pressure Testing Plate W/Gasket
Btt
11-21-2023, 11:55 AM | #3 |
