Old 11-10-2023, 12:06 PM   #1
Kube
Kube's Avatar
Default new distributor?
I may be in the market for a new distributor. Any I should strongly consider? Any I should avoid?
Thanks guys.
Old 11-10-2023, 12:14 PM   #2
ModelA29
ModelA29's Avatar
Default Re: new distributor?
Electronic or points? My car has had the electronic conversion for years.
https://www.fsignitions.com/
ModelA29 is offline   Reply With Quote
Old 11-10-2023, 12:19 PM   #3
Kube
Kube's Avatar
That's a good question indeed.
I have no issue with points. My only experience with electronic has been Pentronix. In my opinion, total junk.
Old 11-10-2023, 01:59 PM   #4
Planojc
Planojc's Avatar
Find an original core and build it yourself. All parts suppliers have everything you need to build an original type distributor. Stay with the points.
Planojc is offline   Reply With Quote
Old 11-10-2023, 02:08 PM   #5
rfitzpatrick
YES, and they're nice to deal with too
rfitzpatrick is offline   Reply With Quote
Old 11-10-2023, 02:37 PM   #6
mcgarrett
Agree with Planojc. You can't beat Henry's stock unit for overall reliability and acquisition cost.
Old 11-10-2023, 02:41 PM   #7
Ruth
Correct me if I'm wrong, but doesn't FSI use Pertronix electronics in their distributors? They for sure use a Pertronix Flame Thrower coil.
Ruth
Old 11-10-2023, 03:03 PM   #8
ModelAArmy
I have FSI distributor for the last year and it has been trouble free. Shawn at FSI is great to deal with and get advice. I highly recommend them.
Tom in Texas
1931 Coupe
ModelAArmy is offline   Reply With Quote
Old 11-10-2023, 05:00 PM   #9
Ordsgt
Ordsgt's Avatar
I have had FSI in my Model A for a couple of years and absolutely no issues. Also have installed in most of my tractors and they were great
Ordsgt is offline   Reply With Quote
Old 11-10-2023, 05:19 PM   #10
AL in NY
AL in NY's Avatar
I've had a FSI Zipper electronic distributor since 2008 (28,000 miles) with NO issues at all. You need to follow the installation instructions to the letter. It's very important to run a third dedicated ground line from the points plate back to the battery.
AL in NY
AL in NY is offline   Reply With Quote
Old 11-10-2023, 05:49 PM   #11
CarlG
CarlG's Avatar
I am distributor poor:
• Brand new original style I bought from Snyder's
• Mallory dual point rebuilt by Jim Linder
• FSI Zipper
• Original, rebuilt by one of our club members.
Except for the last one above, all are on the shelf -- unused.
I did run the FSI Zipper for 5K miles until it failed. FSI rebuilt it, and I even have a spare module for it. I'm now using an original, stock distributor now for the last 15K miles without a hiccup.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 11-10-2023, 08:04 PM   #12
Bigsnapper43
I rebuild distributors to pay for my hobby. Be sure to use the long bushings and the drilled shaft.
Bigsnapper43 is offline   Reply With Quote
Old 11-11-2023, 03:25 PM   #13
cristeven
Highly recommend the new castings from Snyder’s. These come with bushings installed and reamed. Remainder of the parts are also available on Snyder’s.
cristeven is offline   Reply With Quote
Old 11-11-2023, 09:15 PM   #14
Sunny the Model A
Sunny the Model A's Avatar
I like to use original if possible, as far as castings go. As for internals, I love a drilled shaft, and otherwise all stock internals. I daily my truck on original points, condensers, all is well with mine. if you put a little Vaseline on the cam once a month if daily driving they will last a looooooooong time. I set my points at 0.020" and it loves it.
"Ain't but three thangs in this world worth a solitary dime, but A Models, Sweet Tea, and Macaroni Pie!"
Sunny the Model A is offline   Reply With Quote
Old 11-11-2023, 10:33 PM   #15
Synchro909
Synchro909's Avatar
I have an electronic distributor in one car and one with points in the others. Frankly, I can't feel any difference but I make sure the car I use when I'm going to be driving in remote areas has points. IMO, they are just as reliable and all I need to diagnose any problem is piece of wire with a light globe attached. Not so sure about how I'd manage a burnt out electronic module out there but switching points is easy and quick.
Just because something is new, doesn't mean it is an improvement over what went before it.
Even at my age, I still like to look at a young, attractive woman but I can't really remember why.
Old 11-12-2023, 07:35 AM   #16
nkaminar
nkaminar's Avatar
I like points. The original Ford points and condensors lasted forever but some of the repos are not all that good. I use good quality modern points and condensor but carry a spare set (that I have not had to use). I have not had very good luck with the electronic ignition. Just my experience, yours may be different.
Old 11-12-2023, 08:25 AM   #17
Kube
Kube's Avatar
Hi guys.
Well, I ended up going through the OEM assembly once again. Found the lower plate to have continuity between the plate and the contact bracket. The continuity was not a constant. I believe that's why I didn't find it the first time.
I'd replaced the plate with a new one and no more dizzy issues.
Thanks for all of the helpful advice. I continue to learn
Old 11-12-2023, 09:01 AM   #18
lotsagas4u
Hi guys.
I believe you made the correct choice, glad it worked out.
lotsagas4u is offline   Reply With Quote
Old 11-12-2023, 11:44 PM   #19
700rpm
700rpm's Avatar
I have been told that vaseline will dissolve to a watery state and can cause problems. Anyone else hear of that?
Ray Horton, Portland, OR
Old 11-13-2023, 08:30 AM   #20
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
The issue with many of the original cores are they are worn beyond factory specifications. Many never consider this, but the grooves that guide the tangs on the Breaker Plate Assy. are often worn too much which does not support the breaker plate correctly. The correct dimension for this groove is 0.1562".
Additionally, the center of the Dist. Base housing is also worn which does not allow the Breaker Plate to rotate in the true ℄ of the Distributor Cam. This affects dwell and point gap.
With the above said, an original housing can be restored by using a specially made cutter tool and true the groove in a Lathe. Then I put a drop of weld onto each of the 3 tabs, and clamp the plate onto the table of the Mill to machine each drop of weld giving approximately 0.001" clearance in the groove. Also, the center of the Base Housing can be trued while it is in the Lathe. Depending on how severe the wear is, determines how to repair that area. The print calls for this diameter to be 0.715". If the hole in the base plate is within 0.010" or less of the Dist. Base diameter, the base plate can be peined (-as shown in Marco's photo below) however if that number is larger, then the housing needs to be brazed and then remachined to 0.715".
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
