Old 10-27-2023, 02:15 PM   #1
Banditorama
Default Front Brake Actuating Lever Lateral Play
I've got a fairly excessive amount of back and forth play in my brake lever arm on the driver's side. It rattles pretty bad while driving and it's developed a sharp lip that's worked its way over the top of the rod that it resides on
My first question is where can I find the arm? I called Mike's A-ffordable and apparently there's a national backorder on them
Second question is can I use the ones where the brake rod attachment point is offset like in the following link?
https://www.mikes-afordable.com/product/A2084.html
I attached a picture of mine as well. As you can see, the brake rod attachment point is centered as opposed to offset. The tech guy at Mike's said that no one ever made a lever that was centered. Which obviously is not the case.
Thanks for any help!
Banditorama is offline   Reply With Quote
Old 10-27-2023, 02:19 PM   #2
Banditorama
Default Re: Front Brake Actuating Lever Lateral Play
https://imgur.com/gallery/s3gsIFv
Idk why the image deal isn't working. Here's the image I meant to attach
Old 10-27-2023, 03:21 PM   #3
Bob C
According to the Judging Standards the offset arm started in Jan 1930.
Bob C is online now   Reply With Quote
Old 10-27-2023, 03:57 PM   #4
Banditorama
Makes sense, mine is a '29. Kind of weird the tech expert at Mike's didn't know that, but oh well
The judging standards doesn't happen to have a part number for the non-offset arm does it?
Old 10-27-2023, 05:09 PM   #5
ModelA29
ModelA29's Avatar
I ordered one from Snyders a couple weeks ago - https://www.snydersantiqueauto.com/p...7570&cat=41655
Says fits 28-31. Yes if you're working on a fine points car you'll need to find a good used 1929 one. Otherwise use the one that superseded the earlier part.
ModelA29 is offline   Reply With Quote
Old 10-27-2023, 06:23 PM   #6
Banditorama
That is great to hear!
Is it necessary to swap both sides to the new style one, or can I mix and match them? The other side is in fine shape
Old 10-27-2023, 06:46 PM   #7
The Master Cylinder
The Master Cylinder's Avatar
Maybe the Mike's guy meant that no one ever made a repro centered lever, just the offset ones? Or did he say "Ford" never made one?
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is offline   Reply With Quote
Old 10-27-2023, 06:52 PM   #8
Banditorama
I didn't think to ask. Apparently they're interchangeable so, knowing that now, I'd assume he meant no one made a repro one. I didn't know the offset one superseded the original design for repairs
Old 10-27-2023, 08:04 PM   #9
Bob C
The straight one is A-2084-B and the offset one is A-2084-C.
Old 10-28-2023, 05:33 AM   #10
nkaminar
nkaminar's Avatar
You can also use the longer ones for the rear but you will have to add a sleeve and do some other modifications. The advantage is greater braking in the front. The disadvantage is more sensitive brake adjustment.
Old 10-28-2023, 06:54 AM   #11
JoeCB
JoeCB's Avatar
Just wondering, why the change to the off-set arm? Looks like the straight is a better design.
Joe B
JoeCB is offline   Reply With Quote
Old 10-28-2023, 07:38 AM   #12
kenparker0703
The offset is to keep the brake rod from rubbing on the shock absorber adjusting nut.
kenparker0703 is offline   Reply With Quote
Old 10-28-2023, 10:25 AM   #13
Bob C
You can also use AA arms as the are longer than the A ones.
Old 10-28-2023, 10:42 AM   #14
rotorwrench
rotorwrench's Avatar
I remove the rivet and the arm. I braze up the worn parts and either redrill or file the shape back to size and fit things back together. Buck in a new rivet and it's ready to go.
I haven't had a problem with a repaired one yet. The last one I found loose was under a lot of pressure due to a bent front axle. The other side was still tight.
Old 10-29-2023, 08:50 PM   #15
Banditorama
Just an update:
Removed the assembly and drilled out the rivet to remove the arm from the brake actuator. There was what seemed to be a metal shim put in where the lever arm presses onto the actuator. Which leads me to believe this was a problem that was halfway fixed by the previous owner
Idk anything about the history of the car, I just won it at an auction. Someone loved it and poured a lot of money into the body/paint/interior decades ago. But, mechanically it was a mess. This is just another one of the bandaid fixes I've had to correct on it
My plan of action is to take it to a machine shop tomorrow and have them get those assemblies to fit together correctly
Thank you everyone for your help! As always you guys have been great
Old 10-29-2023, 09:40 PM   #16
Bob C
Is it possible you were seeing the dust ring?
Old 10-29-2023, 09:53 PM   #17
Banditorama
No, it was a shim where the round piece of the lever arm slides over the shaft on the actuating arm. Just a thin piece of metal that went in between the two pieces
