Old 10-26-2023, 01:08 PM   #1
duke36
Default Re: Thermostat
There have been internet discussions about installing thermostats without a by pass system used in engines designed for a stat. The rear cylinder on an A may get too hot with potential steam pockets or pump cavitation until the stat opens.
Y, where does one install a draft tube on a stock A engine ? Some run with the B engine larger oil fill pipe. Is that sufficient ?
Old 10-28-2023, 11:00 AM   #2
duke36
Additional draft tube--where/ how to install?
Old 11-05-2023, 09:53 AM   #3
katy
katy's Avatar
https://www.snydersantiqueauto.com/s...searcht=A-6764
Installation instructions there also.
