Hey Terry, I think most people misunderstand this process, ...and quite honestly I used to also.
When you read the Service Bulletins and understand the instruction, the process is not to shim the Flywheel Housing into alignment, ...but the indicator is used to just check the FW Housing to verify it is in alignment. The only place that shims were allowed is in the upper two holes, -and this was to compensate for the gasket thickness. If installing a 0.010" shim in the two holes where the tabs are did not bring the housing into alignment, then Ford specified to install a new housing. New ones are available today, -or some original housings can be machined. I modified a grinder by installing a large faceplate to be able to re-machine a flywheel housing where both sides are coplanar. Click on the link below to see what is happening; https://youtu.be/2GDg5AT2TmI |
#2 | |
![]() Quote:
Terry |
#3 | |
![]() Quote:
Actually, this uses one of the new CBN (-industrial diamond) grinding heads instead of a grinder rock. The CBN does not use coolant, and the surface really does not build heat. I am only taking about 0.002" per cut which really doesn't generate a lot of heat. Most housings will be between 0.010" - 0.020" out, so after I make the last pass that has continuous grinding, I just let it run until it sparks out and then it is dead-on. This also gives the housing plenty of time to cool if there is any heat build-up. FWIW, I have not even bothered indicating one we installed in the last couple of years, as the first ones we did always hit in the 0.001" - 0.003" range which is well within the 0.006" spec. |
Leave the dial indicator above the flywheel a small amount and then use a feeler gauge between it and the flywheel housing.
Dave / Lincoln Nebraska |
