09-20-2023, 10:17 AM | #1 |
Hot Rod oil
Have you ever heard of Hot Rod Oil.
It came in a rectangular metal gallon can. |
09-20-2023, 10:20 AM | #2 |
Re: Hot Rod oil
Brylcreme?
09-20-2023, 11:39 AM | #3 | |
Re: Hot Rod oil
The only thing nice about being imperfect is the joy it brings to others.... "Silver rings, your butt! Them's washers!" "We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969 https://www.youtube.com/watch?v=7NReUd2_0u0 Last edited by petehoovie; 09-20-2023 at 11:55 AM. |
09-20-2023, 11:52 AM | #4 |
Re: Hot Rod oil
09-20-2023, 11:56 AM | #5 | |
Re: Hot Rod oil
09-23-2023, 03:28 PM | #6 |
Re: Hot Rod oil
by the Seitz Oil Products in Syracuse, NY. The third image posted by Pete Hoovie was on the can I saw at an auction. I couldn't believe it went for $1500. |
09-29-2023, 08:32 AM | #7 | |
Re: Hot Rod oil
Back in the day that term referred to used oil that was recycled. The term still applies today. Bob
..."they are only original once" |
09-29-2023, 08:51 AM | #8 |
Re: Hot Rod oil
Ah, back to chemistry class days...
Refining is basically a fractional distillation process where the raw mix is boiled, then because each component condenses at a different temperature you set your equipment up so you capture each fraction (component) as it cools and condenses. I presume with the equipment in common use there was a fair amount of cross-contamination of the various fractions. So a second distillation would help purify each fraction. Then you mix the purified fractions to your secret recipe (and add urbs and ices) to get your snake... er hot rod oil. |
