I will be picking up my 56 next week, I am wondering if anyone can suggest what tie down spots will work the best? I have a 16 foot flatbed and am using 4 inch nylon straps thanks
I have always used front wheel straps and rear axle housing
Thanks I have rear axle straps but can't use wheel strap as I have no place to hook them on the trailer. What about using the lower control arms?
I use the lower control arms. Put the straps as far "outside" as you can. Typically the strap can be captured by the lower ball joint castle nut. I get both sides evenly tightened up then pull as hard as possible on the rear straps.
Bill, certified Ford nut. 2016 F-150 2016 Focus 08 Shelby GT500 57 Ford Ranchero 36 Chevy, 351C/FMX, 8", Mustang II |
That sounds like a plan. I am taking everything I can think of ,plus. I have a check list
put the chain or strap where the brake line tubing is, as you don't want to crush it. .
If mama ain't happy, ain't nobody happy. But if daddy ain't happy...RUN What I GOT DONE TODAY... I put my rear-end in the recliner, and now I'm going to rest up & watch TV. ![]() |
In my trailer now - picked up in
the Boston area - dropping off in Peoria, Illinois … This beautiful 1956 F100 Custom On this truck - 6 point tie down with Mac’s axle straps and nylon ratcheting cable straps. Two on the rear axle straight back from the axle - one on each frame rear corner crossed to the other trailer side - one on each wide slot front wheel straight This eliminates vehicle shift. 5K wide drum synthetic line winch line held taught as a safety line. Every vehicle is different. |
#8 | |
![]() Quote:
I have always left my car in neutral while tying the car or truck down and after its tight I will then put in park sometimes.
If you are trailering your own
vehicle and are certain in will not lock up in gear during transport then putting it in gear is a good idea. Jim |
Well I made it home without any problems. Thanks for all the suggestions,
#12 | |
![]() Quote:
I suggest using a nylon strap run below the brake line very near the brake backplate so the strap will be directly up against the axle housing itself. |
#13 |
Every car is different.
Obviously you don’t want to crush a brake fluid line or any other part when you tie down so use discretion and. good judgment when you place your axle strap. Jim |
