Old 09-03-2023, 02:38 AM   #1
47topless
47topless's Avatar
Question Washers, yay or nay, on stock head studs
Should I use hardened washers, with the stock nuts and studs, when installing the stock iron heads on a 59 AB? Was there a reason that washers were not used originally on these engines?
In my practical mind, it seems like washers would greatly assist in maintaining the torque value, on these nuts, as the engine is run and warmed up.
47topless is offline   Reply With Quote
