Old 08-31-2023, 08:27 AM   #10
jimTN
Default Re: Incorrect 1934 BB Truck bellhousing?
Transmission will work, motor mts are off, fuel pump stand is incorrect, 34 has a long filler tube. Without seeing rear of trans, hard to say whats wrong. I have a 34 trk and will look at the trans mounting to see what can be reversed.Believe the T Tube should be the same for both v8 and 4, the short shaft behind the trans may be the change.
