08-21-2023, 04:00 PM | #21 | |
Re: Jammed door lock set screw
1940 Ford DeLuxe Fordor Sedan 1944 GPW Jeep |
08-21-2023, 05:14 PM | #22 |
Warbird: Before you try other ideas, try using these first. Even if you end up using a couple of sets, it's worth it.
https://www.temu.com/subject/n9/goog...ctx=f-78ce0f3a |
08-21-2023, 05:14 PM | #23 |
08-21-2023, 05:28 PM | #24 |
08-21-2023, 05:34 PM | #25 | |
https://www.harborfreight.com/diamon...ece-69653.html
08-21-2023, 08:28 PM | #26 |
08-21-2023, 11:03 PM | #27 |
If you end needing to replace the treaded tube; get a 10-32 rod coupler. Works great to replace a messed up original. Then use a regular set screw (with a little never-seize) instead of the slotted original style. Not stock; but....
08-22-2023, 01:55 AM | #28 |
Thanks for the info! I've already been starting to think about what I might do if the dremeling does not work.
08-22-2023, 01:56 AM | #29 |
UPDATE: I started to dremel the hole with a diamond-tipped bit... Good news is that it is indeed grinding it out. Bad news is that it's going very slow and already chewed up three bits. So it's going to be a game of patience and how many trips I want to make to Harbor Freight to get more dremel bits. But it seems to be working.
08-22-2023, 04:26 AM | #30 |
Maybe look for a set of carbide grinding tips. They are super hard and sharp and eat through steel like it is warm cheese. I have a set for my Dremel, they are very handy.
08-22-2023, 05:36 AM | #31 |
Just went and looked those up. I like the idea, but they don't seem to be small enough to go into the hole. All the ones on Amazon seem large.
08-22-2023, 06:39 AM | #32 | |
https://www.championcuttingtool.com/...-Carbide-Burs/ Try search for mini or micro carbide burr. |
08-22-2023, 05:36 PM | #33 |
I would try a 1/8 inch 4 flute center cutting carbide end mill in the dremel.
08-23-2023, 07:33 AM | #34 |
08-23-2023, 01:57 PM | #35 |
I spent about five and a half hours drilling out one of those very hard set screws. I wore out some drill bits but I hit one drill bit that was tough and it drilled through enough that an easy out backed out the remaining piece of set screw. It took a lot of patience.
08-23-2023, 03:51 PM | #36 |
An Artu slotted (carbide) drill bit would probably be able to do the job…..
08-24-2023, 08:33 AM | #37 |
The problem with this method is removing the broken drill bit without damaging the threads so bad as to make them useless.
Remember the 'assembly" is made of thin metal. A little bit "off" one way or the other and the threads are toast. While I wish warbird the best of fortune, from experience, I can warn of poor odds of success.
08-24-2023, 08:44 AM | #38 |
Just a thought here... If Warbird can find a LH twist drill bit for drilling out the remainder of the set screw he might get lucky and have the screw unstick and get pulled out by the bit.
08-24-2023, 11:34 AM | #39 |
Unless you get the broken drill bit out first, then there isn't much that can do. Using an end mill would be useless as the broken drill bit is going to snap the flutes of the end mill immediately. The location of the part is the biggest issues as it's almost impossible to get at. I was lucky when I needed to work on the doors on my 1946 Ford Station Wagon as the lock screws came out fairly easy. When I replaced them I used stainless steel set screws and gob's of anti-seize. You might need to do some serious surgery to get the lock assembly out.
08-26-2023, 01:28 AM | #40 | |
