I know there are a couple of ways of mounting a Flathead on an modern engine stand....any NEGATIVES to using the exhaust ports mounting type???? As far as any cracking or stress on the block???
It is widely used, and unlike the bell housing mount, there have been no reports of cracks or other problems caused by exhaust manifold mounting reported on The Ford Barn; at least not in my ten years.
Ford did it, enough said!
No downside to using the exh port mounting as long as the bolts are correct length (not too short). If an 8BA, mount it rear or side...doesn't matter.
Terry
"It don't take but country smarts to solve the problem" (Smokey Yunick) '30 Model A Speedster '41 Merc Town Sedan / 260" 8CM engine '66 Fairlane four door / "warmed up" 302
Rock: For best stability be sure to use an engine stand with 4 wheels.
Here's an example of a homemade stand for my 8BA. It held a completely assembled engine. [url]https://www.jalopyjournal.com/forum/threads/how-much-does-a-flathead-ford-weight.483150/ Use at least 3 in. dia. wheels. If you decide to make one, I still have the parts painted black and can mail you the full size templates. Tools needed: cutting torch, lathe, arc welder or Mig welder. If you loan it out be sure to get it back before it "disappears" and finds a new home. Last edited by 19Fordy; 08-11-2023 at 05:29 PM. |
19forty thanks the the “tip” (no pun intended) and reminder on the 4 wheel stand as I have a 351 cleveland on a three wheel stand and have that constant threat of tipping every time i touch it |
Lincoln use the exhaust ports on the V12's. If it worked for those it will certainly work on a V8. Tim
You can't go wrong doing it the way KR Wilson designed. I really like my KRW stand.
And there is also a concern if those exhaust port mounting bolts are too long. I've read posts where someone mentioned having coolant coming out of the exhaust ports after installing their newly rebuilt engine. They determined the cause to be the use of exhaust port mounting bolts that were too long, and damaged an internal water jacket, and/or a cylinder wall after torquing down those mounting bolts that were longer than necessary. A very expensive and disheartening mistake.
John "Never give up on what you really want to do. The person with big dreams is more powerful than one with all the facts". Albert Einstein Last edited by JM 35 Sedan; 08-13-2023 at 04:16 AM. |
Because guys don’t know how to measure Bolt Depth.
Put down the impact wrenches and don't force things. Problem solved. ![]() Terry
There is a plate you can buy for them, $50 or $60 and it won’t hurt it.
