08-01-2023, 07:12 AM | #1 |
phaeton top
I bought the top bows recently from a place in California. with the bows extended, they sort of fit, just looked a little off. but, when I try to put them in the down position, things go really wrong. They get in such a bind that they will do not fully collapse, actually twist the metal part of one bow, and hit the side of the body. I finally gave up and decided to leave the top off after spending $1500 on the bows and $1700 on the top. I wonder if the bows might actually be for a T model. anyway, any one looking to buy phaeton bows, beware!
08-01-2023, 08:15 AM | #2 |
Re: phaeton top
why not try and return them?
Hershey isnt far away............... |
08-01-2023, 09:27 AM | #3 |
Re: phaeton top
I talked to the person and would not consider it. Also said the bows had been in inventory for 30 years. They look new.
08-01-2023, 10:55 AM | #4 |
Re: phaeton top
That may be why they've been on the shelf for 30 years. Some repro parts work and some don't. Model T irons match the taller windshield. Is this a 28/29 or a 30/31?
08-01-2023, 01:34 PM | #5 |
Re: phaeton top
So what phaeton are you speaking of? Year? Fordor?
I’ve used 30-31 repop before. Old stock were made by Ezra which has long morphed and no longer making car parts. They can be problematic but made to work successfully. Might take tweaking Likely same if 28-29. Deluxe phaeton irons can be difficult too. Right now, I may be the only mfg of those? No sure. Last edited by Oldbluoval; 08-02-2023 at 05:27 AM. |
08-02-2023, 06:58 AM | #6 |
Re: phaeton top
08-02-2023, 07:13 AM | #7 |
Re: phaeton top
I only make deluxe not the tubular ones for std.
08-02-2023, 07:25 AM | #8 |
Re: phaeton top
thanks anyway.
08-05-2023, 11:25 AM | #9 |
Re: phaeton top
ExOilFld - If the vendor refuses to stand behind their products I’d like to know who it is so I don’t use them. The Model A community benefits when honest feedback about vendors is shared.
The fact that the bows have been in inventory for 30 years is irrelevant.
David in San Antonio Late ‘30 / early ‘31 Deluxe "Wretched Roadster" Alamo A’s Club |
08-06-2023, 07:18 AM | #10 |
Re: phaeton top
No longer available, but they should fold like this
https://www.fordbarn.com/forum/showp...99&postcount=6 |
08-06-2023, 09:39 AM | #11 |
Re: phaeton top
Folding irons on all the old touring types have to have a fair amount of accuracy on the distances between the holes of all the hinge points. The axis of the through holes also need to be accurate with little or no deviation. If a person has a specific arm that is not flowing well through the arc of motion then it can bind or twist depending on the problem at hand. If a person could identify what the cause of the problem is then it may be repairable but not without the capability to weld up holes and properly redrill for best fit. There can also be fabrication of part, patches, or hinge pins and installation of same.
As was mentioned, it can take more than just some tweaking to get them to function as intended. The top wood parts also have to be correct for normal function. If anything is off by much then it will need to be corrected. It's always a good idea to fit the folding top mechanism and do the work prior to installing the canvas or vinyl top materials. |
