Front wheels on car ramps.
Remove the lower front splash pan from behind the radiator. Insert a fitted cardboard up onto the radiator surface for protection. Remove distributor caps, then remove distributor. When replacing, use longer studs in 2 of the 3 mounting holes to locate the distributor correctly. Do not tighten mounting bolts until seated firmly and correctly on the block.
Alan |
