Ok how do I get the cam out.... pulled yje back cover and theres 2 gears do I have to pull one.....also the oil pump isnt budging so theres got to be a trick to getting it out of there
FLATHEAD ADDICT |
ok i got the cam out....not sure the right way but its out.....the oil pump still wont budge
FLATHEAD ADDICT |
Try twisting and pulling. Some can be stuck pretty tight.
Be careful I broke the ear off mine prying and twisting. Zeke
Only problem with retirement is never a day off ![]() |
thanks I hit it a couple of times and it didnt budge so I wanted to seel advice before I started yanking on it
FLATHEAD ADDICT |
Use some of the 50-50 mix as well, this stuff really works.
yep ron I have a batch mixed always....thats how I got this flathead tore down.....wish I could get a 50 gallon drum of the 50/50 mix and soak the hole engine
thanks for the advice Ill take a crack at it tomorrow as Im wore out from scrubbing flathead valve assembly's in the parts washer
FLATHEAD ADDICT |
hey does the large gear at the back come off or can I leave it on during the cleaning of the block
FLATHEAD ADDICT |
I'd take the idler gear out to make cleaning easier. There's a tapped hole in the stub shaft it rotates on. Attach a slide hammer to the pin and knock it out. Very simple. JMHO. Good luck.
Ok thanks guys I now have the cam out and pulled the oil pump(wow did it have a bunch of crap in it when I pulled it) and tonight Im pulling the gear and off to the hot tank it goes.....thanks again for the insight
FLATHEAD ADDICT |
#13 |
#14 |
Aw, man, is that all you were talking about? I was hoping the formula somehow involved wild animal urine as the secret ingredient....What a disappointment.
#15 |
not that exotic but it does the trick.....and if you use evapo rust
FLATHEAD ADDICT |
#16 |
Don't forget to remove the oil galley plug in the front behind the timing gear. It's a good idea to use a long narrow brush (ie rifle barrel brush) to clean out the tube. DO NOT FORGET to replace the plug on the rebuild.
VANPELT SALES LLC Cincinnati, Ohio Office: 513-724-9486 www.vanpeltsales.com www.classictransmission.com |
#17 |
The only way to properly clean this passage is to remove the fuel pump pushrod bushing so you can get a clear shot through the tube.
