Old 06-28-2023, 07:11 PM   #1
classic car repair
Default piston
I have a flathead V8, 1938 85 truck, looking for new pistons - STD, piston has 91A on the piston, mic out at 3.06-3.08, I was wrong, they are dome type piston, 3 rings only, having a hard time fine a place to buy them, STD piston, Need stop, if someone can help and tell me who sale them. You can E-Mail me [email protected]
Thank You Lee
classic car repair is offline   Reply With Quote
Old 06-28-2023, 08:13 PM   #2
Ken/Alabama
Ken/Alabama's Avatar
Default Re: piston
Not sure I’ve seen a 91A piston with a flat top. I thought by 1939 they were all dome top.
Old 06-28-2023, 08:20 PM   #3
Lawson Cox
Lawson Cox's Avatar
Default Re: piston
I'm with Ken.
Old 06-28-2023, 08:50 PM   #4
Brian
Brian's Avatar
Default Re: piston
the above answers are correct, inasmuch as a 1938 engine should be equipped with dome top pistons. Have a look at the cylinder heads- see how they are domed to provide clearance for dome top pistons? Try all the regular suppliers for STD 3 1/16" domed pistons.
Old 06-29-2023, 06:59 AM   #5
Bored&Stroked
Bored&Stroked's Avatar
Default Re: piston
Post a picture of your pistons and heads (the chambers) - and what your block's bores look like.
As others have noted, these engines usually come with domed-top pistons - with heads that match. If the engine had true flat-tops and the heads are domed-top, then you had very little compression and the engine would run very poorly. As Brian noted, if it has the pistons that should be in it, then it is easy to find 3 1/16 pistons (stock Ford 221 cubic inch pistons).
If you have the engine all torn down, the bores need to be measured with an accurate dial-bore gauge to see if it is possible to use STD pistons and re-ring it, or if it really needs to be over-bored for a bigger oversize piston - like .030 over.
I've never taken apart an older engine that didn't need to be over-bored (they ran the heck out of these things before and during WWII), but I'm a bit of a perfectionist. If I see too much piston to bore clearance, taper, out of round, etc - I put new pistons/rings in it.
Old 06-29-2023, 07:34 AM   #6
nickthebandit
Default Re: piston
Try Foundry Street classic Parts. 1-413 -283-7620. Brian is there on Fridays and
Saturdays. He has an untold amount of early parts available.
nickthebandit is offline   Reply With Quote
Old 06-29-2023, 08:24 AM   #7
classic car repair
Default Re: piston
you are Right and I recheck after I clean the top off, they dome piston
Old 06-29-2023, 08:25 AM   #8
classic car repair
Default Re: piston
They are dome top piston, I had to recheck and clean off the top, Sorry, but you are right
Old 06-29-2023, 08:35 AM   #9
classic car repair
Default Re: piston
I remic the piston and they are 3.06 but I was wrong on the piston top, I recheck and clean off and they are dome type
Old 06-29-2023, 08:37 AM   #10
classic car repair
Default Re: piston
I recheck and I was wrong, they are dome type
Old 06-29-2023, 01:28 PM   #11
Ken/Alabama
Default Re: piston
Barnfind08 here on the Ford Barn will probably have them New Old Stock.
