Old 06-14-2023, 06:05 AM   #1
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: Woven vs molded linings for cast iron drums
Originally Posted by mhsprecher View Post
I have had the drums for a few years. I had the hubs installed and the drums turned. I realize that the shoes need to be arched to the drums. As with most projects, it is more complicated than originally thought.
Milford, you are very correct. As research towards accurate or authentic restorations have been done over the past decade or so, it is realized just how good original Model-A brakes truly were when they are as they came from the factory. To correctly restore a set of brakes to make them "as good as original" is definitely more complicated than most hobbyists thought, -or think. It honestly requires more jigs, fixtures, and tooling to restore them correctly than most hobbyists have access to.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
