Old 06-08-2023, 12:39 PM   #41
Raaf
Default Re: Reports on Burtz new engines
Thank you Dave - this is very helpful.
Do you have an idea of how much horsepower you're making with the Serr + 97?
Raaf is offline   Reply With Quote
Old 06-08-2023, 11:08 PM   #42
Dave in MN
Dave in MN's Avatar
95hp at 2800 rpm.
Jim Brierley ground a cam for me that provided greater torque at a lower rpm.
I designed the car to pull a small camper and keeping the rpm in check was my goal.
Good Day!
Dave in MN is offline   Reply With Quote
Old 06-09-2023, 06:47 AM   #43
jack backer
I’m building a 5 cam bearing Burtz and am considering a Serr head as well.. two things give me pause, one is the cost of horsepower, roughly 150 bucks per horse..the other is at the end of the day you’ve built a Pinto or Iron Duke for a whole lot more than you could buy one..
But hey the kids will be too busy spending my money to waste time lining my casket with it..
jack backer is offline   Reply With Quote
Old 06-10-2023, 07:42 AM   #44
updraught
updraught's Avatar
Originally Posted by nkaminar View Post
JayJay,
I tried the tube header and straight (open) exhaust but the stock exhaust manifold and Ares performance muffler is just as good and not nearly as noisy.
I can't see how most tube headers are going to work as most are not turned length pipes to create the suction of having even flow pulses. Also, the low compression means there is not much energy available to do much. Low compression needs low restriction in the muffler. Too wide an exhaust pipe could lead to drain where exhaust doesn't flow fast enough. This seems to be forgotten in modern post turbo times.
updraught is offline   Reply With Quote
Old 06-10-2023, 08:17 AM   #45
jack backer
It’s difficult to achieve extraction with a modified model A flathead engine exhaust system. Header doesn’t provide intake manifold heat beneficial to performance.
A header is sexy and the sound is unique..
Old 06-14-2023, 12:25 AM   #46
Dodge
The best combination is a stainless steel muffler that is ceramic coated. They offer many colors. Black would be good. I used the titanium color on my headers 3yrs. ago and
they still look great. If you get oil or some other stain on it you can brake clean and
scotch brite it off.
Dodge is offline   Reply With Quote
Old 06-14-2023, 01:05 PM   #47
Dan McEachern
Dodge- who do you use for ceramic coating?
Dan McEachern is offline   Reply With Quote
Old 06-14-2023, 05:28 PM   #48
JayJay
I used a bake-on ceramic from a rattle can that I picked up in my local NAPA store, and it's holding up fine. It went from gray to a sort of gray-gold during curing in the oven (don't tell my co-pilot!) but has held steady color in use. Sorry I don't recall the name of it. I also got another can from one of the vendors, might have been from Snyders, and that's working fine as well.
JayJay
JayJay
San Francisco Bay Area
1930 Murray Town Sedan
1931 Briggs S/W Town Sedan
It isn't a defect, it's a feature!
