06-13-2023, 07:00 PM | #1 |
1929 Model A rear wheels
I have been helping a relative work on his collection of Model As
and I have run into something I don't know about. When the car is going sown the road, the rear wheels wobble. I have already checked and made sure the rims aren't bent and that the lug nuts are tight. Is this a major repair or something simple that can be taken care on the car? |
06-13-2023, 07:29 PM | #2 |
Re: 1929 Model A rear wheels
Sounds like when the rear hubs/drums were put on the key rode up a little bit in the axle while sliding them on.I would check for that first before looking for bent or warped parts.
06-13-2023, 08:20 PM | #3 |
Make sure that the rear axle nuts are torqued to approximately 100 ft.lbs
06-15-2023, 06:04 PM | #4 |
Have you switched the wheels on that car? I couldn't find it again but I think that some wheels didn't sit tight on the drum allowing them to flex/warp when tightened down.
06-15-2023, 06:46 PM | #5 |
Thank you for all the responses. Gives me a starting point to
look at before tearing the car apart. |
06-15-2023, 11:02 PM | #6 |
06-16-2023, 08:28 PM | #7 |
