Old 08-03-2011, 08:09 AM   #1
Ron Lowe
Default hood removal
Getting ready to fix my wobbling fan problem. I don't have anyone to help me lift off my hood. Has anyone ever made something to hold the hood after you remove the radiator. I have fresh paint on the hood. My only neighbor is Dad and he's 87. Thanks Ron
Ron Lowe is offline   Reply With Quote
Old 08-03-2011, 08:14 AM   #2
5_guy
Default Re: hood removal
Do you have an engine hoist (Cherry picker)?
5_guy is offline   Reply With Quote
Old 08-03-2011, 08:18 AM   #3
Ron Lowe
No I don't. I thought about renting one but that seemed a little silly.
Old 08-03-2011, 08:19 AM   #4
Brother A
Brother A's Avatar
Ron,
Where are you? Perhaps one of us is close enough to give you a hand.
Steve
Brother A is offline   Reply With Quote
Old 08-03-2011, 08:22 AM   #5
Elcastor
Elcastor's Avatar
You should be able to take the hood off first, then the radiator.
Ben Purkey
Mexico and the Pacific NW
http://www.martin-parry.com/
Elcastor is offline   Reply With Quote
Old 08-03-2011, 08:34 AM   #6
bogdonj
bogdonj's Avatar
Depends how how much you can lift? I can usually take it off myself by bringing both sides of the hood up and resting them on the gas tank and then grabbing it and lifting it off in one try.
Then again I'm 6 foot 1 and 200 pounds!
_________________________________________
1931 Ford Model A Tudor
1930 Ford Model A Deluxe Roadster
1930 Ford Original Rolling Chassis- Restoring
bogdonj is offline   Reply With Quote
Old 08-03-2011, 08:50 AM   #7
Ron Lowe
Thanks for the offer Steve, but I'm a little to far. Pittsburg,Ks ( southeast corner of Kansas )
Old 08-03-2011, 08:55 AM   #8
MCHinson
MCHinson's Avatar
This works for me. Remove the rear hold down bolts. Carefully open the hood and prop it up. Walk to the front of the car, step over the bumper and stand in front of the radiator. Grab the hood, supporting the weight of the hood on top of your arms. Slide it towards the rear of the car slightly to clear the front bracket and lift it up off of the car. Carefully step over the bumper and away from the car. Gently place the hood on a piece of carpet, resting it with the back edge of the hood on the carpet.
MCHinson is offline   Reply With Quote
Old 08-03-2011, 09:00 AM   #9
Bruce
Bruce's Avatar
I agree with Ben. You can probably just snatch it off.
First one I took off I rigged rope and eyebolts to apply the lift. All that kind of got in the way and I was forced to just step in and do it!
I've found that the tough part is stepping over the bumper with your arms full of floppy sheetmetal. Take the bumper off first if you aren't confident in your ability to high step!
Bruce is offline   Reply With Quote
Old 08-03-2011, 09:08 AM   #10
V4F
V4F's Avatar
put towels between the hood half's to prevent chipping the paint . have a plan b 4 you start . i do it all the time by myself ..........
V4f
V4F is offline   Reply With Quote
Old 08-03-2011, 09:13 AM   #11
Bruce Lancaster
Maximum access without actually lifting: drape a piece of soft cloth over the whole hood to protect paint. Open hood on both sides, supervising your cloth so it stays between the hood top panels and over the sides, bring hood fully up so both top panels are vertical and together, and run a bungee cord from one handle over the top to other handle. Handles can be nicely padded with a piece of heater hose split to go over them. Take care in the padding, choose a bungee that exerts fairly low pressure, choose a piece of cloth that won't get you divorced...
Old 08-03-2011, 09:16 AM   #12
Keith True
Keith True's Avatar
I take them off from the right side.I fold the hood up,with the two tops together.Left side still hanging down.If the paint is a worry I stick a towel between the two parts.Then I grab the front and rear,near the hinge pin,pinching the two top halves together with my fingers.I just slide it out of the front retainer,and pick the whole thing up.I got used to doing it from the right because my trucks have the spare tire on the left.If you forget to unlatch the hood on the drivers side you will figure it out in a hurry.
Old 08-03-2011, 10:02 AM   #13
ChicagoBob
ChicagoBob's Avatar
I've done the side-lift method a few times (1930 Tudor), but my paint isn't that great. It helps to put a piece of hose between the top pieces and between your fingers, not too near the hinge, so you dont rub the hood tops together excessively.
It's also good to store the hood on its rear edge on a rug or carpet, somewhere where kids, dog or wife won't knock it over or drop a suitcase on it while trying to remove same from a high shelf (don't ask me how I know).
ChicagoBob is offline   Reply With Quote
Old 08-03-2011, 02:28 PM   #14
Rainmaker Ron
Rainmaker Ron's Avatar
On a restored car the hood hinge pins were likely freed up and restored along with the rest of the car. My 3 door hood is very heavy so I slip the side hinge pins out and remove the hood sides first. The top is easy to handle without the sides.
Rainmaker Ron
Rainmaker Ron is offline   Reply With Quote
Old 08-03-2011, 02:52 PM   #15
LukeDahlinger
I put both sides up, use my arms like a forklift in the curved portions of the hood and it comes right off. No need to get all fancy or take things apart...
Wanted- Feb. 1931 Parts Price List
www.vintagefordfacts.blogspot.com
LukeDahlinger is offline   Reply With Quote
Old 08-03-2011, 04:47 PM   #16
Louis
All good idea's, If you don't have carpet to set it on, I have used a large piece of cardboard, Also be carfull with the rear hinge hold down when you lift the hood as it can come off and fall down behind the eng. and get hung up, most of the time it will fall to the floor or on top of the gas tank.
If this is your first time it sure would be nice to have an extra set of hands.
Good luck.
Louis is offline   Reply With Quote
Old 05-18-2023, 06:52 PM   #17
tom2588
[QUOTE=5_guy;250329]Do you have an engine hoist (Cherry picker)?[/QUOTE yes]
tom2588 is offline   Reply With Quote
Old 05-18-2023, 06:53 PM   #18
tom2588
How to remove hood on 1931 model a
Old 05-19-2023, 06:44 AM   #19
nkaminar
nkaminar's Avatar
Here is my solution: This from a bicycle hoist. The pulleys are mounted on plywood which is attached to the ceiling with a distance apart less than the length of the hood. This keeps the hooks on the hood.
Old 05-19-2023, 10:48 AM   #20
1931 flamingo
1931 flamingo's Avatar
I've done it with a short piece of 2x4.
Paul in CT
