Old 05-08-2023, 12:15 PM   #1
old31
Default Re: Battery Disconnect Switch
So the issue of not being able to turn off a running car with a alternator still exists, whether it be a negative or positive interrupt.
I just tried it on my car. I have an alternator and the kill switch is on ground. The car was running and and the kill switch could not turn the car off. DUH!
Does anyone have a fix for this?
old31 is offline   Reply With Quote
Old 05-08-2023, 01:15 PM   #2
Y-Blockhead
Y-Blockhead's Avatar
We are talking disconnect switch not kill switch. Your ignition switch wouldn't turn it off either?
Same if you blow the fuse people install on the starter, Alternator continues to feed ignition.
You could have your wifey pull the coil wire??
I have a fuse in the ignition circuit so I guess I could pull that if I was ever in that situation.
I also have my ignition circuit wired so the ignition switch is before the coil.
Old 05-08-2023, 01:25 PM   #3
Phil Brown
Phil Brown's Avatar
https://www.speedwaymotors.com/Speed...4aAgZeEALw_wcB
goes in the non-ground side
Phil Brown is offline   Reply With Quote
Old 05-08-2023, 01:27 PM   #4
johnneilson
Yes, this is a common problem while confusing a battery disconnect switch for kill switch. There are high amp disconnect switches with 2 NO contacts, one for battery and another for the ignition or charging system.
Adding a relay probably will not correct the issue.
J
As Carroll Smith wrote; All Failures are Human in Origin.
johnneilson is online now   Reply With Quote
