Old 04-08-2023, 05:23 PM   #1
Kingo
Default Help with Luggage rack
What am I missing in installing the luggage rack? I was under the impression that without the rear spare tire I didn’t need the extensions.
File Type: jpeg 5627F850-840C-4448-9FB3-DDCA6AE959BC.jpeg (89.0 KB, 132 views)
File Type: jpg EC19DD8D-BBEA-4C60-BB84-763175F931A5.jpg (53.1 KB, 107 views)
File Type: jpg 6FBFC8B1-0179-4D5E-A8D9-18CAA18FCB48.jpg (47.5 KB, 100 views)
Kingo is offline   Reply With Quote
Old 04-08-2023, 06:00 PM   #2
J Franklin
J Franklin's Avatar
Default Re: Help with Luggage rack
What seems to be the problem? It justs bolts on to the last 2 holes.
Old 04-08-2023, 06:14 PM   #3
Bill Cilker
Bill Cilker's Avatar
The luggage rack uses the two blots in front of the bend in the bumper bracket.
Here is the luggage rack on my Victoria. Yours will bolt in the same position. The large cutout in the support bracket is specific to the Victoria.
Bill Cilker, Jr
Unrestored 190A Victoria
45B, 160B & 189A
Victoria Association President
Bill Cilker is offline   Reply With Quote
Old 04-08-2023, 09:48 PM   #4
Kingo
That is how I was thinking it went. But, The rack I have is to narrow between the brackets to go over the bumper bracket (31.25”).
Old 04-09-2023, 12:07 AM   #5
J Franklin
J Franklin's Avatar
They are built to fit. I doubt the rack is the problem. Maybe someone with a rack can give the measurement it should be.
Old 04-09-2023, 07:53 AM   #6
Ed in Maine
The distance between the bumper brackets (outside surface) is 30 1/2 in. on my 31 Victoria. The extension brackets do have a special cutout to go around the sheet metal apron at the back of the Victoria. I couldn'd buy these and had to cut them myself with a hack saw and grind them, what a job!
I love the luggage rack on the back but worry about someone hitting in the rear which will damage the apron. This is a hard part to find. Ed
Old 04-09-2023, 08:58 AM   #7
Kingo
Well, now, I’m thinking the problem is with the crossbar brace. The car is a may 1930 town sedan and the brace is a three hole 1929.
Old 04-10-2023, 10:45 AM   #8
KenBolton
If you’re mounting a reproduction and it sags you may need to fab and install supports.
KenBolton is offline   Reply With Quote
Old 04-10-2023, 11:47 AM   #9
Smokedtires
Smokedtires's Avatar
I had to open up the bracket mounting holes when I installed mine. With the bolt through the drilled hole, the slot was off by about a 1/4 inch to short.
Smokedtires is offline   Reply With Quote
Old 04-17-2023, 08:48 PM   #10
Kingo
I hate to admit it but I still am having problems figuring this deal out. The rear bumper assembly is turned upside down and the luggage rack is set on top of the rear bumper bracket and it’s the same width as the brackets. Shouldn’t the rack brackets be wider and bolt to the outside of the bumper brackets?
File Type: jpg 13B69C66-1F32-49C8-8541-F3E2620297B8.jpg (139.9 KB, 62 views)
File Type: jpg 621403E7-27EC-4384-BC9D-D3085D2805DC.jpg (147.1 KB, 56 views)
Old 04-18-2023, 10:29 AM   #11
Cape Codder
Cape Codder's Avatar
Kingo- I have a '30 Fordor Blindback! I just measured outside to outside which is 29 3/4". I measured at the piece in your picture that goes straight from the end of the bumper to the cross piece. Not being an expert, BUT are you sure you have the correct cross piece installed?
Wish you luck with the project as I'm sure you are frustrated with it!
I don't care if the "A" Starts BUT sure WANT IT TO STOP!
Cape Codder is offline   Reply With Quote
Old 04-18-2023, 11:50 AM   #12
1930artdeco
1930artdeco's Avatar
My 30 TS is set up just like your and my reproduction luggage rack bolted right up. but I have a spare tire and ordered the extension. I can look closer when I home tonight.
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 04-18-2023, 04:49 PM   #13
Gene F
Gene F's Avatar
Is it possible that the mounting on the trunk rack goes outboard of the bumper brackets, and the rack swings down inboard of the bumperettes?
Old 04-18-2023, 04:51 PM   #14
Kingo
The cross brace is the early 30 three hole style. Cape can you post a picture of yours. My town sedan does not have a rear spare tire.
Old 04-29-2023, 05:06 PM   #15
Kingo
Well, I figured it out.
The 29 cross brace measure 29 7/8” over all
The early three hole 3 month brace measures 29 3/4”
The two hole 30 cross brace measures 29 1/4”.
Using the two hole cross brace the luggage rack fits as it is supposed to.
File Type: jpg C3C2BE8E-C9D2-401A-82AE-BDE9E90A12E6.jpg (41.4 KB, 11 views)
Old 04-29-2023, 06:40 PM   #16
Gene F
Gene F's Avatar
Thank you for letting every one know the results.
