Old 04-09-2023, 09:22 PM   #1
Model A Ron
Model A Ron's Avatar
Default American Classic Radial Tires
I just mounted a set of American Classic Radials on my 29 Phaeton and hope to take a test drive this week after I finish up a little more work on the car. I hope to find a much improved ride over the bias firestones. Does anyone know how many miles to expect from the radials? I would think much more than bias tires.
Model A Ron is offline   Reply With Quote
Old 04-10-2023, 05:29 AM   #2
Rob Doe
Default Re: American Classic Radial Tires
I just mounted 4 new radials. They provide a much better than the worn out tires that were replaced. I put the balance beads them too. I used Bratton's tubes. So far so good.
"It ain't what you know for certain that gets ya in trouble. It's what ya know for certain that just ain't so!"
Rob Doe is offline   Reply With Quote
Old 04-10-2023, 03:55 PM   #3
Dean Lemoine
Dean Lemoine's Avatar
9,600 miles on these American Classics on a ‘29 Tudor. I was running 38 PSI but noticed the centers are wearing more than the outsides. Dropped down to 35 PSI and will monitor wear.
File Type: jpg BC98F57F-FCC8-4721-9A28-4EED146B2F03.jpg (23.6 KB, 104 views)
Dean Lemoine is offline   Reply With Quote
Old 04-10-2023, 04:23 PM   #4
Y-Blockhead
Y-Blockhead's Avatar
Good info Dean, Thanks for the feedback.
Old 04-17-2023, 05:47 AM   #5
Model A Ron
Well I got my A running a little better with a timing adjustment and setting the points so I decided to test the new tires. Over the weekend I drove about 100 miles with them set to 40psi and I noticed they tracked much better than the old bias tires. One road around hear had me shifting left right all the time and this was no longer a problem with the radials. The ride was about the same in terms of softness and when I felt the sidewall after driving they were just a bit warm and not hot. Next I will drop to the recommended 35psi and see if they are any warmer and if the ride improves in terms of softness. Overall I am very happy with the tires but need to accept the radial bulge not seen on the bias tires.
Old 04-25-2023, 05:23 AM   #6
Model A Ron
I dropped down to 35psi and the ride improved a lot. Someone said the sidewall was hot at 35 but I did not find this to be the case. What I did fine is a tire that does not track in the ruts and a soft ride that is a big step up from bias tires.
Old 04-25-2023, 05:27 AM   #7
Model A Ron
Dean
Based off the first 9600 miles how many miles do you think you will get out of the set? Do you see the need to rotate them at this time?
Old 04-25-2023, 05:33 AM   #8
Model A Ron
This is what they look like on my car.
Old 04-25-2023, 06:33 AM   #9
Dean Lemoine
Originally Posted by Model A Ron View Post
Dean
I rotated them about 4000 miles back. I’m hoping to get 20K miles out of ‘em, but that’s just a guess. I’m wondering how this is comparing to anyone else running the American Classics. I really don’t know how long these have been on the market.
Old 04-25-2023, 07:56 PM   #10
Model A Ron
I think they came out on 2020 or so but I was hoping we would get more than 20k. If anyone has them please chime in with millage and tire condition.
Old 05-06-2023, 09:18 PM   #11
Drancher
Has anyone used these tires on the stock 19" rims running tubeless? I am running 35 16" with modern radials for six years and have had zero problems. I have a set of 19" stock wheels and have ordered the American classic 475/500R -19 tires and would like to run them tubeless and am wondering if anyone else has done this.
Drancher is offline   Reply With Quote
Old 05-07-2023, 09:14 AM   #12
goldie
I recently purchased the American Classic radial tires and set pressures to 35, the max for this tire. Why do people add more pressure than the manufacturer states I don't understand. I have a British performance car that requires a tube because the rims are not the safety type with the additional lip. I have been running these without tubes for years with no problem, but. The but is in the event of a flat the tire is more prone to separate from the rim. On the As tiny tires I would not take the chance of going tubeless.
goldie is offline   Reply With Quote
Old 05-07-2023, 10:20 AM   #13
katy
katy's Avatar
To check inflation pressure against how "the rubber meets the road" put a chalk mark, about 1/2" wide, across the face of the tire, drive in a straight line for about a half a block and look at the chalk mark. If it's all worn off, the inflation is good, if the middle is worn and the sides are still there the tire is overinflated. Easiest is start w/overinflation and work down.
Old 05-09-2023, 11:38 AM   #14
Dick M
Dick M's Avatar
Send a message via Yahoo to Dick M
Can you use a stock tube with the radial tire or do you need to buy a radial tube?
Dick M is offline   Reply With Quote
Old 05-09-2023, 12:01 PM   #15
Seth Swoboda
Seth Swoboda's Avatar
I have never understood the "radial tire tube". I am runnning bias ply looking 6.00 x 16 tires on a couple of V8 Fords. I put a new tube in them and have been happily motoring for years.
Someone explain to me what a radial innertube is in comparison to an innertube. I have also never been able to find specifically "radial innertube".
Old 05-09-2023, 02:08 PM   #16
Y-Blockhead
I have some tubes that have "Radial" molding into the stem but on the side of the tube it says "Not for use in radial tires". Go figure...
Old 06-30-2024, 02:01 PM   #17
DJ S
DJ S's Avatar
Anyone have updates on wear?
DJ S is offline   Reply With Quote
Old 06-30-2024, 04:01 PM   #18
Dean Lemoine
11,800 miles on American Classic Radials. I’ve been keeping 35 PSI. All 4 are wearing at the same rate.
File Type: jpg 44399959-287F-485E-BB20-2A4A1EE674AC.jpg (35.3 KB, 24 views)
Old 06-30-2024, 04:17 PM   #19
nkaminar
nkaminar's Avatar
Pressure depends on the weight of the car. 35 psi may be OK for a light phaeton but may be too low for a heavy Fordor. The tires should not get so hot after 20 minutes of driving at 50 mph that you cannot hold your hand on the sidewalls.
The radial tires flex different than the bias ply tires and run hotter so the tubes are made differently. If you are not running the tires too hot then the standard tubes may be OK. The only difference I can see is that the radial tubes are about twice as thick.
Running them tubeless may be OK. I have a friend that does that with his 19 inch radial tires. A lot depends on the condition of the wheels. Pitted wheels may not hold the air.
Old 06-30-2024, 05:35 PM   #20
goldie
I drive my A pretty hard on the American Classic radials. Lots of hills and twisty roads. Measuring the tread depth of all tires compared to the new spare the fronts have worn down 1/3 after 6K miles, the rears less so time to rotate. My get 15K miles out of these.
